Old 04-14-2009, 08:02 PM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
can someone please flatten
I have taken from R4 TO MAXSURF but it will not flatten, squish makes nonsense of it
Old 04-14-2009, 10:01 PM
Previous Member
Rep: 0 Posts: 0
When I load it to Delftship there is something screwed up in the detail at the bow. I have attached the curvature plot. The plate is shown bottom up. The detail could be fixed up but it looks like there is some notching for some connection??
Apart from this detail the plate should be developable as the curvature is not particularly tortured elsewhere.
Rick W
Old 04-14-2009, 10:33 PM
Previous Member
Rep: 0 Posts: 0
Rick W
thanks can you email that to my email addrsss(not here) so I can have a look in Rhino 4
was not aware delftship could do thsi, do you have pro vs?
cheers
Old 04-14-2009, 11:01 PM
Previous Member
Rep: 0 Posts: 0
Stu
I have Delftship pro. (I was using it so much that I thought it only reasonable to make a contribution.)
I only loaded your igs file. I have not made any corrections yet. I tried to sort out the problem but I keep making a hole in the plate that I have not been able to repair.
I have attached a dxf file simply generated from your igs. Not sure if this still has the overlapping surfaces as I cannot access a control net in dxf.
If I persevered I expect I could fix the plate. Let me know if you want me to work on it for a bit.
Rick W
Old 04-15-2009, 03:18 AM
gwboats gwboats is offline
Naval Architect
Rep: 68 Posts: 89
Plate development
Try turning on Control Points in Rhino and I think you will see your problem at the forefoot!
The mesh needs to be much simpler in this area.
Cheers,
Graham Westbrook
Old 04-15-2009, 03:32 AM
Previous Member
Rep: 0 Posts: 0
thanks men, I have dfx the yacht was built in Multisurf, at this stage I am just trying work out plate needs
I can not post much more because of copywrite,
I am not a cat builder,this will be my first---- must admit I like this one, well designed by Bloomefield Start build in about 3 months
Old 04-15-2009, 04:18 AM
Previous Member
Rep: 0 Posts: 0
my partner in this(bh nautika) used diff input in maxsurf, so managed to flatten, said there were indeed something odd in forefoot,
anyways there will have to be a seam in the thing as there is considerable compound, you can stretch form most up to 600mm wide, this section is 1200plus , ah well, done it many times before
Old 04-16-2009, 03:09 AM
Previous Member
Rep: 0 Posts: 0
here tis in workshop
I do not understand why they say(strain) as after it is stretched and formed it,ll fall on I will put two butts and one seam in it though to manage it in the wheels
Old 04-20-2009, 07:53 PM
Rep: 206 Posts: 391
It looks like you have a very large amount of strain within a very small portion of the plate, however this could just local ripples in the surface caused by a few bad control points and not affect the overall plate shape. It would be worth trying to clean the surface up in the area shaded blue.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 04-21-2009, 01:16 AM
Humberto's Avatar
Humberto Humberto is offline
Rep: 55 Posts: 35
Actually is not a problem of simplicity. I have imported and activated column view only in jSDN and this is what you get (attached pictures). The problem is that control point column 24 is placed forward than column 25 (and 26, 27, etc). This produces a singularity there (which is shown in the Gaussian plot). A solution may be just simply removing control point column 24.
I hope this helps.
Humberto Martinez
can someone please flatten-column23.png  can someone please flatten-column24.png  can someone please flatten-column25.png
Humberto Martínez Barberá
jSDN Yacht Design Software
Old 04-21-2009, 01:31 AM
Previous Member
Rep: 0 Posts: 0
thanks both, I will build it a little over size anyway and scribe it down to the keel and above plate lines On this particular plate I just wanted a near enough shape as when I stretch this and form it, if it were cut to workshop, and my forming was not (in line) in would not be exact anyways
Aluminium is very forgiving, if you make shape in the plate very close, you can pull it around and down to lines easlly Some of the boats I plate have 48 plates, ,
When I made the change from steel way back I was staggered at the props of al al
I am not a CAD man these were the surfaces as supplied
Old 04-21-2009, 05:41 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
Yes, aluminum is very forgiving, but wouldn't it be better to eliminate this problem at the root (i.e. at design stage), rather than oversizing, cutting, hammering etc the sheets to make them look smooth?
This is clearly a design error, all you need is to get back to the designer and tell him there are some mis-aligned control points. He might then send you back a correct (and developable) hull model.
Old 04-21-2009, 05:44 AM
daiquiri's Avatar
ll you need is to get back to the designer and tell him there are some badly aligned control points. You will make him a favour too, because this stuff has also probably led to a wrong shaping of ribs, girders, bulkheads etc. He will then send you back a correct (and developable) hull model.
flatten patterns Boat Design 4 12-10-2001 07:30 PM
