| Can rhinomarine cauculate Cross curves of stability? I have readed the manul of rhinomarine ,but i didnot know how to cauculate cross curves even it can cauculate righting Arms cruves ![]()
__________________ http://www.theboatpictures.com boat pictures |
| I haven't seen cross curves in RhinoMarine, but the hydrostatic report is written to an xls file, so you may add it yourself, probably into a template so it's always there. |
| thx Raggi!
Could you give us the cell formulas you use to do this? Or maybe the template, as I am a lazy guy and there is so much data in that report I'm not at all sure where the best place to start is (I'm using RhinoMarine 4). Thanks! BillyDoc |
| Run the analysis for a range of flotation planes, simply take your cross curves from the data for each heel angle for each displacement and plot a new graph accordingly. You may need to compartmentalize your tanks and assign the COG accordingly for worst case since I don't think rhinomarine has "free surface" .
| Thanks Mike! |
| Leak stability in RhinoMarine Could this be a suitable solution: First, calculate hydrostatics with a sound hull and pick up displacement and LCB. Then cut off the leaking compartment of the model and calculate hydrostatics/CG (use previous LCB and displacement). The model trims and heels nicely. |
| Thanks from me also Mike :-) |
| Norman Cross Trimaran | Jerry_Lincoln | Multihulls | 47 | 08-03-2011 06:19 PM |
| Rhinomarine For Submarine Stability | Casper | Software | 1 | 12-13-2006 12:14 AM |
| Vortex Generatos vs. Cross Keels | Pat Ross | Multihulls | 5 | 07-18-2006 01:24 PM |
| Need Cross Sectional Area Curves preferably For A Passenger Ferry | Jurach | Boat Design | 0 | 03-10-2006 08:52 AM |
| Wanker 36 stability curves, understanding | tranmkp | Sailboats | 1 | 07-26-2004 07:15 PM |
