| Calculating Volume in Rhino Hi everyone, I'm trying to calculate volume in Rhino but it says all surfaces need to be closed and I don't know how to join them all. It's half a hull at the moment and this is what I've done in an attempt to seal it. |
| Jordie. . As you are not able to undertake the basic process, then u need to train yourself to amature level in Rhino. Get hold of a manual (download one) and start from there. Good luck.
__________________ Regards, Mark Bambury, Managing Director MBM Consultancy GMBH & Co.KG www.mbm-consultancy.com |
| 1) Find adjoining naked edges with ShowEdges 2) Join naked edges with JoinEdge Consider using the Hydrostatics command which calculates volume and a number of other useful quantities below the specified waterline height without having to close the top of the hull, and has an option for using only half a hull.
__________________ David Cockey |
| ShowEdges and JoinEdge are briefely covered on p22 of the Rhino 4.0 User's Guide.
| I recommend to arrange or re-build the surfaces in way, so that you can make a closed polysurface or Solid by those surfaces. Then you can simply use the command : Analyze>Massproperties>volume
__________________ Md. Al-Amin Pavel http://www.paveldesign.tk "A question that sometimes drives me hazy, am i or are the others crazy?" Albert Einstein |
| Rhino Rhino Rhino (hull thickness, offset surface, and unrolldvp for cnc cutting) | metin_mehel | Software | 11 | 10-11-2011 12:10 AM |
| Calculating volume | rasorinc | Boat Design | 11 | 04-08-2010 01:01 PM |
| Volume calculator | Hisham | Software | 1 | 03-27-2006 09:16 AM |
| Rhino - calculating the surface | Maciej | Software | 7 | 06-07-2005 01:01 AM |
| Volume of a Half-Diamond For Hull Volume Displacement | Free Pirate | Boat Design | 2 | 03-11-2005 03:24 AM |
