| Calculating the forces of my boat against a float in weather I am looking for some help. I do not have a background in hydrodynamics or naval architecture. I have a need to calculate the potential forces my 32' boat will excert against a floating dock in various sea conditions. My goal is to determine if the (float/piling) structure is sufficient to handle the size of my boat. I have determined the range of expected wave amplitudes / periods for my location. I am in the process of working out the pile lateral load capacity and deflection at the ground surface, as well as the float attachment strength. The key piece of information that I need is the force potential of my boat in various sea states. I want to assume worst case, which I understand would be the sway of the hull resulting from waves in the direction abeam of the the boat. If I can determine the boat's acceleration caused by waves in the direction towards the float, then I can determine the potential force applied to the dock. I would like to know, do any of you know where I can get access to software that can provide this information with the entry of the characteristics of my boat (LWL, draft, keel profile, displacement.. etc)? I know this software exists, but what I have found is expensive. I am not designing ships, I just need it to solve my problem. Is there any free or nearly free software out there that can do this for me? Thank you, Dean |
| Hull speed | Mike D | Boat Design | 33 | 02-27-2011 02:20 AM |
| Auto engine marinization | DIY Marinizing | 231 | 07-01-2010 08:34 PM | |
| High-Speed Waveless Boat | waveless | Boat Design | 82 | 10-10-2005 08:01 AM |
| Boat Design Proj | designfreak | Boat Design | 31 | 04-15-2005 03:20 AM |
| geometry of sailing | Sailboats | 8 | 10-12-2002 11:58 AM | |
