Old 01-11-2017, 02:47 PM
papiylon papiylon is offline
Rep: 10 Posts: 4
Calculate Catamaran Resistance in Maxsurf
Hi all,
I am currently designing a small recreational catamaran for a school project using Maxsurf. I have both of my hulls in the Resistance module and I am looking to obtain the graph of the resistance vs. the speed.
However, there are many analysis there and I was wondering which method should I select ( Analysis --> Methods...) to obtain the most accurate results? I tried calculating it by hand, but I do not have the required information for the wave resistance.
Cheers,
Rosalie
Old 01-11-2017, 06:07 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 2488 Posts: 5,201
Rosalie
What is the length-displacement ratio (LD) of your design?
Old 01-12-2017, 11:02 AM
Rep: 10 Posts: 4
Its made for a user of 115 kg and the two hulls has a lenght of 4.5m ... if I am not mistaken, the ratio is 37.5 !?
Old 01-12-2017, 05:25 PM
Naval Architect
Rosalie
No, the displacement is to the power of 1/3.
So your L/D ratio is 9.3. This means it is very slender, so if you select a method that uses long slender body theory, like the series 64. I don't have maxsurf, so I'm not sure what methods of analysis are available.
Old 02-20-2017, 08:09 PM
Rastapop Rastapop is offline
Naval Architect
Rep: 46 Posts: 278
You will want to use the "Slender Body" method in Maxsurf.
Calculate resistance using Michlet; Errror:Bad displacement sps5749 Software 12 04-25-2014
08:06 AM
Can SHIPFLOW calculate and simulate appendages resistance for planing hull? H.Hisyam Software 0 05-20-2011
03:50 AM
Can Maxsurf (or Hydromax) calculate what angle boat will sit in water? Michaelp Software 4 04-07-2011
03:40 AM
Can Maxsurf Calculate Bojean's curves? samcool111 Stability 2 06-24-2010
10:26 PM
how calculate power and resistance of a lcvp zeroname Propulsion 0 12-03-2009
12:27 AM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
