| cal in autohydro how can i calculate hydrostatic in different trim condition in autohydro? it looks so hard. must i input a trim data,then cal the hydrostatic with command--GHS? and how can i calculate it in different heel condition in autohydro? |
| Set the desired trim with the TRIM command. (You could use the DRAFT command instead) Set the desired heel with the HEEL command. Then the HS command (not GHS) will give you hydrostatics at the trim and heel you have set. HS ignores the VCG and lets you roll the boat around anyway you like. |
| yes ! it can be calculated! thank you so much! but why is it "hs",not "ghs"? what different between these two command? do you have some booklet about how to use autohydro? |
| Check the help file for both commands. Pretty good explanation of the difference there. |
| yes i have found it thank you aboatguy but could you explan then different bitween "frozn","spilling" |
| In reference to tanks: Basically, The surface of the liquid in a frozen tank does not move as the vessel trims or heels (as if it were frozen). A spilling tank is similar to a normal tank until the surface of the liquid passes a predefined reference point. At that point the contents "spill" from the tank and the load is decreased. Unlike the real world, tanks 'unspill' if the angle is decreased. Check help file under TYPE (I believe). |
| my pal cal connell | gasdok007 | Boat Design | 1 | 02-04-2009 10:05 AM |
| command llimit in autohydro | Thai | Software | 6 | 05-03-2005 09:06 PM |
| how to define a damaged condition in autohydro | hello | Software | 0 | 03-08-2005 08:31 PM |
| cal 2-29 | trimhorn | Sailboats | 0 | 06-21-2002 02:24 PM |
| lines plan for cal 2-29 | trimhorn | Boat Design | 0 | 06-20-2002 03:45 PM |
