Old 02-16-2009, 09:20 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
CAD dwg. file to Maxsurf Pro
Hi fellas, I am trying to see if I can put a CAD dwg. file somehow into Maxsurf to save redrawing it all, and cannot do it....sorry, but I am only learning this electronic drawing game, and it is very hard without personal instruction.
Is there any simple way to do this please?
Old 02-17-2009, 03:59 PM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
Landlubber what kind of files are you trying to import into maxsurf. Surface files or line drawings. Surface files you can import as “iges” but if they are not nurbs then you are going to end up with a mesh with hundred of control points which may not be of much use. Line drawings both 2d and 3d can be imported as “DXF”; these can then be used as a template to add maxsurf surfaces to what is required. Before import into MS, line drawings sometimes also need to be in a vector form (curved lines are made up of small straight sections) before conversion to DXF, your cad programme should be able to do this.
Old 02-17-2009, 05:09 PM
Landlubber's Avatar
The file is a dwg. file, lines plans of my boat, but it does not open in Maxsurf.
Thanks you for your help.
Old 02-17-2009, 05:23 PM
apex1
load it again and save as dxf that should do.Maxsurf (as I know) does´nt know dwg.
Regards
Richard
Old 02-17-2009, 05:34 PM
Landlubber's Avatar
Ta, I will try that.
Old 02-17-2009, 05:39 PM
Landlubber's Avatar
Nup, it does not recognise dxf. either........
Now I am sad.....
This is very frustrating. I have spent hours on this and got no where.
Old 02-17-2009, 05:51 PM
Rep: 547 Posts: 540
landlubber as I mentioned sometimes you have to convert to a vector drawing where curved lines are made up of short straight lines.If you can't do this with your cad program I may be able to help with the conversion for you.
Old 02-17-2009, 07:24 PM
apex1
Now I am sad.....
Understand the frust...
which kind of exotic CAD is it?
Regards
Richard
Old 02-18-2009, 02:07 AM
Landlubber's Avatar
AutoCad 2008...I am sure the problem is me......
Old 02-18-2009, 04:54 AM
Rep: 547 Posts: 540
Landlubber do a test, draw a 3d box using lines only with one corner on the 0,0,0 point, then export it as DXF then import that into a new drawing in maxsurf. This should work as it made up of lines, no curves, also you don’t have to get the right way up or around the right way on the import side.
Old 02-18-2009, 04:55 AM
apex1
Sorry, but I must agree. It is error # 59 unable user. DXF is the natural format of Autocad, it MUST be possible to "save as" in dxf. Try to rename it (dont change the format) like example.dwg to sample.dwg, then open with autcad and save as example.dxf then import to Max.
Hope it funxt.
Regards
Richard
Old 02-18-2009, 06:01 PM
Landlubber's Avatar
I still think my problem is not error #59, but ID10T (Idiot)....but I will persist, thanks fellas so much for trying to put a brain where none exists.
Funny, I feel so competent with anything boat stuff, done it all my life, but this CAD designing/drawing game is a whole new kettle of fish.
Old 02-18-2009, 06:19 PM
apex1
I feel with you.... I learned my CAD Program (Megacad) about 15 - 16 years ago on a double circumnav. without any assistance, just everything autodidactic.
But I wonder where are all the professionals here to step in? I am for shure not one of them (still cannot manage 3D proper).
Regards and success
Richard
Old 02-18-2009, 07:24 PM
Rep: 547 Posts: 540
Landlubber here is a line drawing of sections of a boat in DXF format. Try to put it into a new maxsurf drawing. Go to “import” then to “DXF background” then in the import options just pick “maxsurf default”,see what comes up
Old 02-18-2009, 07:37 PM
Landlubber's Avatar
It says "The File you are reading is incompatible with this version"
maxsurf workshop pro lazeyjack Software 1 07-25-2007 08:27 AM
Converting Pro/e file to rhino Coen Software 3 01-15-2007 10:15 AM
after having a dxf file from maxsurf academic pavel915 Software 0 11-26-2006 08:37 AM
Convering .hul to cad file - is it possible? Rasman Boat Design 12 06-13-2005 10:00 PM
series 60 lines / CAD file DaveB Boat Design 0 08-09-2004 02:12 PM
