| Caculating data from inclining test Hi all After we have all figures from inclining test. How could we do calculating with them for getting exactly data for the ship like CG,VG,Diplacement...? Do you know any software or caculating table about that.Could you please give me some advices about calculate these data. Thanks forward. Toda |
| try this one |
| Thank you very much for your file Fiko. I will see it and if some problem occurs i will ask you again. I hope you won't refuse my question. |
| Dear Fiko I have seen your file, but some data from it. I still don't understand. 1. On Result tab you wrote T Ap=2.609m and T Fp=0.85m but on Light ship tab you had Draft at AP=2.85m and Draft at FP=1.35m? 2.You used 2 pendulums of course they had different deviation on inclining test why you didn't use tolerance between their differ? Awaiting for your answer. Thank you very much |
| Dear Toda 1. Sorry Tod, I use other ship to calculate, but it’s should same number. (This my file few years ago, and I don’t check it up again). After u get u T AP and T Fp, u can run ur model in Hydromax ( I use it) in specification condition and copy result to lightship tab (C4-c29) 2. I use 1 pendulum, and that number have not deviation, it’s only example to find range of deviation, in real inclining test that number should be not same .its said range between 5.24 until 21.25,u must in this range if u use length of pendulum and distance like my file.( min 1 deg- max 4 deg)u can change it and it’s chance range automatically. Thanks. |
| The absence of test data for sails | ivor Bittle | Boat Design | 23 | 05-03-2008 02:28 AM |
| Drop test | dougfrolich | Open Discussion: All Things Boats & Boating | 3 | 07-25-2007 06:58 PM |
| test reports | jeemboNC | Boat Design | 0 | 01-16-2007 08:54 PM |
| Nedd help with ASTM for USCG inclining exp on T boat | capn-jer | Software | 2 | 03-30-2006 09:40 PM |
| need help -- inclining experiment calculation | jerryah | Boat Design | 8 | 12-02-2005 08:47 PM |
