| Buying the right design software? I want to buy a design software program, have tried demo versions of Prolines and RhinoMarine. As I understand it, You can use Prolines to do the hull design but then You need a second cad program to do all the final design, and in RhinoMarine You can design the hull, deck, structures, fittings etc.? I find Prolines very easy to use, but would be pleased to hear other users experience with these programs! By the way, I want to concentrate about RIB designs and workboat designs. Thanks! |
| I use 4programs, in general a Hull modeler, a surface modeler a MCAD for parts and a CAD software Freeship+Rhino+Solidworks or Alibre+Autocad LT or intellicad, works fine but any other combination will do the job. Maxsurf, prosurf, Freeship +Rhino or Touchcad+Solidworks or Solid edge or shipconstructor (but you need to add Autocad full version)+CAD There are software's that can probably handle all but is all about budgets and what really works, for example Freeship+rhino can be used to do all (hull design hydrostatics and structural including cnc and 3D modelling in general and about expander is a good "add on" to rhino but you still can create some developable surfaces using rhino so expander is not required. All the programs i mentioned i have used and they do their part, again i think budget is important and for the type of boats you want any of the mentioned will do, i used prolines before but is not close to freeship or maxsurf or prosurf, it's a good software but i found the others more complete. cheers |
| Design Software? | Neverbehind | Software | 14 | 03-15-2006 04:09 AM |
| Best Marine Design Software for Hull Design? (2001-2005) | Admin | Software | 113 | 12-31-2005 11:40 PM |
| Design Software needs | Millar time | Software | 9 | 08-29-2005 10:22 AM |
| Design software | RockReeve | Boat Design | 1 | 02-09-2005 08:31 PM |
| buying ship design software | Archive | Software | 30 | 01-17-2005 06:27 PM |
