| Boat Design Software I have designed a whole line of offshore fishing boats that range from 35' to 79' feet. The designs look good on paper in 1 dimension. I've looked at the software thats posted on the site and I havent found anything that Im looking for. If anyone has a software to recommend, PLEASE DO!!! If you could recommend a software that is easy to use and can give me 3D renderings of my designs. I highly appreciated it. Thanks ![]() |
| Hello Fisherman I find Rhinoceros the easiest to use for the work I do, it has an easy interface and is good for 3d visualisation of a proposed design. Additionally it has an inbuilt basic hydrostatics info and accepts a range of usefull nautical software plugins.
| Hello Fisherman, I suppose my suggestion would be considered hardware instead of software. Why not make a half model and look at it held up to a mirror? It only takes a day or so. There are mirrors which reflect of the front of the glass which gives you a better representation. It is called two way glass. I'm suggestion this because you did not mention anything about computers or CAD in your post. If you are not using CAD already it will take many days to learn. If, on the other hand, you intend to use computers for future design work you should go ahead and pay your dues. Best wishes, Gilbert |
| Check out TouchCAD. Easy to use and a powerful general purpose modeler. Simultaneous dynamic cross sectioning over any number of surfaces and any number of control points in any number of objects can be edited at the same time. All control point on the objects and not vaguely beside it. Built in marine, weight and center of gravity calculations. Very extensive built in unfolding and production preparation features. I essentially design all major panels with it. www.touchcad.com
__________________ Claes Lundstrom |
| Boat design software |
| Some ideas | yipster | Projects & Proposals | 81 | 02-15-2006 01:32 AM |
| boat design software | ciao8167 | Boat Design | 1 | 06-29-2005 12:01 AM |
| Boat Interior Design Software | Guest | Software | 9 | 05-15-2004 04:21 AM |
| Rudder design for solar boat | lost at sea | Boat Design | 9 | 01-26-2004 12:39 PM |
| Folding Boat Design | Archive | Boat Design | 0 | 06-12-2001 04:18 AM |
