View Poll Results: Which program(s) do you use as your primary hull design software?
Autoship 14 7.82%
Catia 5 2.79%
DefCar 1 0.56%
Delftship 28 15.64%
Fastship 3 1.68%
Freeship 24 13.41%
HullCAO 1 0.56%
Hull Form 4 2.23%
Maxsurf 64 35.75%
MultiSurf 7 3.91%
Naval Designer 1 0.56%
Napa 7 3.91%
NX 5 2.79%
Prolines 1 0.56%
ProSurf 2 1.12%
SolidWorks 5 2.79%
Rhino 63 35.20%
SeaSolution 0 0%
TouchCAD 1 0.56%
Other (please post below) 10 5.59%
Multiple Choice Poll. Voters: 179. You may not vote on this poll
Closed Thread
Old 01-23-2010, 10:18 PM
hienbkship hienbkship is offline
In Korea, they often use Nupas Cadmatic and Xbase (Hanjin Heavy Industry and STX) for design step. XBase is made in Korea and use Sikob database. Do you have any experience of it?
Old 01-25-2010, 03:34 AM
patc's Avatar
patc patc is offline
Rep: 36 Posts: 20
call me cynical, but shouldnt the poll be more like
"how many users are there of the following software on Boatdesign.net"
How many voters have used 5 or 6 or the different packages to be able to make a sensible comparison as to which is best?
BTW Im a developer for Maxsurf so Im pleased to see it leading at the moment, but Im not really too sure how useful this type of poll is if you are in the market to buy some new software
pat couser - area65, france
Old 01-26-2010, 11:58 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2356 Posts: 2,479
I don't see Freeship in the list?
Old 01-28-2010, 05:24 AM
patc's Avatar
Rep: 36 Posts: 20
Delftship == Freeship ???
Old 01-28-2010, 05:45 AM
daiquiri's Avatar
Delftship != Freeship
Old 01-28-2010, 08:46 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
Freeship is under the free or low cost software poll...next one down.
Old 01-28-2010, 03:28 PM
Jeff's Avatar
Jeff Jeff is offline
Moderator
Rep: 921 Posts: 1,371
Yes, when Delftship first came out, Freeship was replaced with Delftship in that year's version of this poll (I believe 06/07.) I've now re-added FreeShip as an option in this poll as well.
Old 01-28-2010, 09:55 PM
workboat's Avatar
workboat workboat is offline
Rep: 10 Posts: 12
shipconstructor?
inventor?
Old 02-14-2010, 03:45 AM
Admin Admin is offline
www.boatdesign.net
Rep: 42 Posts: 40
Originally Posted by workboat View Post
shipconstructor?
inventor?
I must admit I am not up to speed on inventor - the last time I demoed it very briefly was much closer to its beginning than the current time. The poll started focused on hull surface modelers; over the years we've added programs but I didn't include inventor because I think of it as a modeler for structures and components but not a hull modeler. How is inventor currently being used for boat design? Any neat examples and/or a quick inventor overview would be appreciated.
Old 03-18-2010, 04:16 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 252
i will suggest SC ..
DAre To DreAm
Old 03-19-2010, 07:24 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 1943 Posts: 4,195
I use Freeship because it's free and I know it a little and I don't know most of those softwares, so it's a good idea to have them listed, it gives us the opportunity to look at them also.
For the most part I think it is about what you design. Obviously if you're into canoe's I doubt you'll go for the $100k software. The big boat designer may not go for Freeship... but it all depends on your budget and how big a tax problem you have.
Regards
Fanie
Water ! Just gimme water !
Old 03-25-2010, 06:52 AM
MBM MBM is offline
Rep: 10 Posts: 31
The best software is the software that provides you with what you need as a result.
When we need a graphical format we like to use Inventor.
When we need t oconvert a linesplan PDF to CAD to a Working hull for motions analysis we prefer accuracy and that means Rhino , in our opinion.
That does not mean this is correct. It just means we are willing to pay the price to get the job completed to the level we require at industry standard for our clients.
It depends what you clients demand from you as a service.
This is the key to this survey.
If your client is satisfied with your level of output using teh software you use, then that is the one for you.
Thus, an added question should be applied to this survey -
Q - what vessel/industry is the hullform generated from the software?
Old 03-25-2010, 08:27 AM
maodou maodou is offline
Rep: 10 Posts: 25
All the soft above looked like for 3D design ?why not autocad,the basic and the usual soft used by most people.If i select,napa + autocad+maxsurf+shipconstructor is enough
Old 03-27-2010, 01:43 AM
pistnbroke's Avatar
I try
Rep: 372 Posts: 1,230
you must be all very clever I downloaded Freeship and oh no too much for me ..the best I can do is Carene 2008..but I dont build ships only boats...perhaps I should stick to thai longtails !!!
Closed Thread
Best Free or Low Cost Marine Design Software? (2008-2010) Admin Software 107 01-09-2011 11:42 PM
Best Marine Design Software for Hull Modeling? (2008-09) Admin Software 123 01-20-2010 04:19 AM
Best Marine Design Software for Hull Modeling? (2007) Admin Software 91 04-08-2008 04:12 AM
Best Marine Design Software for Hull Modeling? (2006) Admin Software 95 01-01-2007 02:59 AM
Best Marine Design Software for Hull Design? (2001-2005) Admin Software 113 01-01-2006 12:40 AM
