View Poll Results: Which program(s) do you use as your primary hull design software?
Autoship 14 7.82%
Catia 5 2.79%
DefCar 1 0.56%
Delftship 28 15.64%
Fastship 3 1.68%
Freeship 24 13.41%
HullCAO 1 0.56%
Hull Form 4 2.23%
Maxsurf 64 35.75%
MultiSurf 7 3.91%
Naval Designer 1 0.56%
Napa 7 3.91%
NX 5 2.79%
Prolines 1 0.56%
ProSurf 2 1.12%
SolidWorks 5 2.79%
Rhino 63 35.20%
SeaSolution 0 0%
TouchCAD 1 0.56%
Other (please post below) 10 5.59%
Multiple Choice Poll. Voters: 179. You may not vote on this poll
Closed Thread
  #31
Old 05-30-2010, 04:14 PM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
Unlike aviation...there is no regulation regarding designing for you own personal use. Once built...the boat would normally have to be inspected to ensure you have the required safety items and that any built in fuel and engine systems meet required specifications for venting. Even though you are in Canada...
Download this and it will give you a really good idea of what you need to design and build to. Make sure to check with Canadian authorities to see if it covers everything for you .
http://www.angelfire.com/ego/lewisbo...CGPamphlet.pdf
You will need some kind of .pdf reader and it is best if you save a copy on your harddrive.
  #32
Old 05-30-2010, 09:05 PM
Damian888 Damian888 is offline
Damian888
Rep: 10 Posts: 8
Thank you, I will definitely look at this, this is exactly the answer I was hoping for.
  #33
Old 05-30-2010, 09:19 PM
pistnbroke's Avatar
I try
Rep: 372 Posts: 1,230
when you have your boat on carene then save as an XYZ file and import into freeship ...not Delftship as only in freeship can you develop plates ( tools icon ) and print them out with all the measurements on them ... Uk no good for a 18ft speedboat ..north sea rough ..weather cold
  #34
Old 05-30-2010, 09:58 PM
Damian888
Rep: 10 Posts: 8
Thanks, that helps, I got carene and Delftship, I was not aware of the advantages of freeship... On the other hand, I think the Canadian Great Lakes are ideal for a 18ft speedboat, (in the summer).
  #35
Old 05-31-2010, 01:05 AM
pistnbroke's Avatar
I try
only the free delftship has limitations
  #36
Old 06-04-2010, 10:29 PM
Andrew K Andrew K is offline
Rep: 10 Posts: 2
AutoCAD
Hello. Actually, I'm beginner in marine design. I would like to know. What are the main points/reasons when designer use AutoCAD, after working in 3D software such as Maxsurf or AutoShip.
Thanks
  #37
Old 06-19-2010, 05:07 PM
The Loftsman The Loftsman is offline
The Loftsman
Rep: 10 Posts: 16
Some of the stuff on this thread is amazing to say the least, is it a competition or can the software do what it is you need it to do, or more to the point do you know what it is you really require from the software?
The Loftsman
  #38
Old 06-24-2010, 09:07 AM
HakimKlunker's Avatar
HakimKlunker HakimKlunker is offline
Navigare necesse est
Rep: 111 Posts: 149
No matter which software: It is only as good as the man who operates it Oops: woman?
  #39
Old 07-09-2010, 08:38 PM
Trent308 Trent308 is offline
AutoCAD??
I have seen it mentioned a couple times but no responses to the question? Is there a fundemental reason why its not even on the list? I am assuming its the price. But - just beginning to dabble in boat design (personal fantasy) and have used AutoCAD for years.... Cant get it to "Shell" my 3D solid / hull for the life of me... many approaches I wont list here but nothing seems to be working... Inventor same results (both Autodesk products- vastly different tho). My conclusion is there is something fundementally missing in AutoCAD these contestants may have? Thoughts??? How is SolidWorks???
  #40
Old 07-09-2010, 09:53 PM
Rep: 111 Posts: 149
Hi Trent:
I also had AutoCAD and similar troubles.
When I was recommended Rhino, I found a tool that was just the right thing for me. It was very easy to learn to operate it. And looking into the statistics above, I seem to be no exception.
Meanwhile finished a couple of projects drawn with rhino and - guess what - they all float correctly
  #41
Old 08-01-2010, 03:19 AM
santoo's Avatar
santoo santoo is offline
Rep: 10 Posts: 34
I think i just need Rhino and Maxsurf only to make a boat design..??
  #42
Old 08-01-2010, 07:54 AM
zeroname's Avatar
zeroname zeroname is offline
Naval Architect
Rep: 90 Posts: 252
@santoo:
it depends on what type of work you intend to do. A single software will not offer you the complete solution making boat design. Maxsurf and rhino are popular. But it doesn't necessarily mean that those will suits for you too !
Free!ship as its free , much popular one too.
So, try to know your work and then get the right software , which one you feel easy and effective for you !
and i think , better if u start with Rhino first.
DAre To DreAm
  #43
Old 08-06-2010, 01:00 AM
khabiran khabiran is offline
Rep: -1 Posts: 5
sure maxsurf is suitblae for every type of vessel
  #44
Old 08-13-2010, 07:31 PM
wardd wardd is offline
Rep: 443 Posts: 925
Out of curiosity how much does maxsurf cost?
  #45
Old 08-13-2010, 10:32 PM
zeroname's Avatar
Naval Architect
Rep: 90 Posts: 252
Best if you follow this for pricing
http://www.formsys.com/maxsurf/sales/pricing
DAre To DreAm
Closed Thread
Best Free or Low Cost Marine Design Software? (2008-2010) Admin Software 107 01-09-2011 11:42 PM
Best Marine Design Software for Hull Modeling? (2008-09) Admin Software 123 01-20-2010 04:19 AM
Best Marine Design Software for Hull Modeling? (2007) Admin Software 91 04-08-2008 04:12 AM
Best Marine Design Software for Hull Modeling? (2006) Admin Software 95 01-01-2007 02:59 AM
Best Marine Design Software for Hull Design? (2001-2005) Admin Software 113 01-01-2006 12:40 AM
