| View Poll Results: Which program(s) do you use as your primary hull design software? | |||
| Autoship (Autoship Systems Corporation) | | 13 | 6.19% |
| Catia | | 10 | 4.76% |
| DefCar (DefCar Engineering) | | 0 | 0% |
| Delftship | | 28 | 13.33% |
| Fastship (Proteus Engineering) | | 2 | 0.95% |
| HullCAO (HullCAO) | | 1 | 0.48% |
| Hull Form (Blue Peter Marine Systems) | | 2 | 0.95% |
| Maxsurf (Formation Design Systems) | | 59 | 28.10% |
| MultiSurf (Aerohydro) | | 10 | 4.76% |
| Naval Designer | | 2 | 0.95% |
| Prolines (Vacanti Yacht Design) | | 4 | 1.90% |
| ProSurf (New Wave Systems) | | 3 | 1.43% |
| Rhino (Robert McNeel & Assoc.) | | 53 | 25.24% |
| SeaSolution | | 0 | 0% |
| TouchCAD | | 5 | 2.38% |
| Other (please post below) | | 18 | 8.57% |
| Voters: 210. You may not vote on this poll | |||
#106
| I concur, some of the best modeling tools are not listed. I use Freeship to generate basic hull lines, then import them into NX and do all the detailed design there. NX has a shipbuilding module, but it's overkill for most smaller boat design applications. |
#107
Problem with CADDS5 (besides being ancient) and Catia are the hugemongous expense in the purchase of the software and the very steep learning curve. Both of which are totally unneccessary for pleasure craft but are probably worth the investment for large-scale ship design.
__________________ Rick Beddoe s/v Soņadora, 1978 Baba 30 Senior Designer, Sons Creative "Study nature, love nature, stay close to nature. It will never fail you" - Frank Lloyd Wright |
#108
| When you design a hull you wrap a surface around the target measurements and coefficients. Then it is more useful to look at packages that can do this automatically and actually compare them. Shipbuilding is quite different to hull modelling. Shipbuilding packages and addons all work similarly. Ship design is of course a collaborative team effort and shipbuilding modules facilitate that and add some special modules for piping cabling etc. Sure that makes them more capable. However for 'boat' design it would be excessive to buy and use this type of package. The simpler the cheaper and the lower the learning curve the better it is. I put a budding engineer with no more than Autocad experience on Rhino, by the end of the day he was working with it producing complex solid models for analysis. In a small design office designing boats not ships I think you would be hard pressed to beat Rhino with the Rhino-marine or the Orcad addin if you use it to its full extent it's surprisingly capable for it's cost.
#109
Unfortunately, its not that simple.
__________________ Andrew Mason Formsys http://www.formsys.com Maxsurf Academic http://www.formsys.com/academic/maxsurf/ |
#110
| Andrew With a print out of hydrostatics, it is that simple. Since it is just a moment change owing to the distance between the CoG and CoB horizontally. |
#111
| Unfortunately, its not that simple. For small changes of trim with relatively constant hull shapes the approximation is reasonable. Larger differences between LCB and LCG, or hulls with bulb bows or overhangs will require iteration
#112
| Andrew Within a computer environment this may well be the case. But from a naval architecture, looking at the design spiral, it isn't. It is very simple. Since minor errors or differences are ignored in the first few stages of the design. The hydrostatics will tell me if i have a 30 or 40tm moment to overcome, for example. If it indicates a 0.3 or 0.4tm moment, in the early stages of design, not worth considering, since other factors will come into play which will affect this value later anyway. But a 30 or 40tm moment is not so easy to overcome once the design has been "set". |
#113
#114
| Andrew yes, i suspected as such, hence my qualifier re: with a print out of hydrostatics and in a computer environment. |
#115
| There is one software that should be listed here. orca 3d. It is rhino based tool, and not that expensive. The key players for "orca 3d" are the guys who has created fastship, now fastship belongs to aveva. Fastship should be also in the list. |
#116
| not really a pro i agree on that, at leisure still trying maxsurf whitch is an excelent program! heard of orca before, fastship i had my hands on once for hours at a show and not in the list? |
#117
| Using SW2008 at the moment. It works fine for the simple hulls we are doing. But I tried exactly 1 realitively complex shape and realise this ain't the program to really be using for Hull Design. I also have Rhino and RhinoMarine, but aside from importing files from SW to run Hydrostatics i haven't really used them. |
#118
| It's a shame really, because SWorks has terrific surfacing tools except for hulls! The converging profiles at the bow are the biggest problem. It's actually due to the surfaces being too accurate. The surface manipulation tools are too localized for the surface. Rhino's (and others, I presume) abilty to edit surfaces using a controling net overall allows for more general hull fairing. I keep hoping SWorks will do something about this. There is a tool that allows freeform editing of the surface by directly edting isoline, but that is not general enough and stops short of the net-editing ability in Rhino. OTOH, SWorks is great for developable surfaces. The sheet metal functionality built in to SolidWorks is pretty incredible. Also too, I feel SolidWorks is one of the best for modeling everything else. In terms of hulls, I go back and forth between SWorks and Rhino. In SolidWorks, it's very easy to 'expand' a 2D lines plan. You can then import the 3D lines into Rhino and use network of curves to map the surface. Then import the surface into SolidWorks. SolidWorks keeps one-way associativity to the Rhino model, so if you make a change in Rhino, it will update in SolidWorks. Very handy.
#119
| I like SolidWorks with MultiSurf... But NX works - > It was made for 20 min And another example ->Inland foreship NX works... |
#120
| The great advantage of NX is doing everthing in one software packet. So hull design, fairing, basic hydrostatics, GA, basic design, detailed design, workshop drawings, expansions, cutparts, FEM calculations, simulation etc.. NX's kernel is the Siemens Parasolid Kernel so for advanced stability calculations GRC's Paramarine is perfect. It is also working on Siemens Parasolid Kernel so you can directly import solid data from NX and calculate. |
| Best Free or Low Cost Marine Design Software? (2008-2010) | Admin | Software | 107 | 01-09-2011 11:42 PM |
| Best Marine Design Software for Hull Modeling? (2007) | Admin | Software | 91 | 04-08-2008 04:12 AM |
| Best Marine Design Software for Hull Modeling? (2006) | Admin | Software | 95 | 01-01-2007 02:59 AM |
| Best Marine Design Software for Hull Design? (2001-2005) | Admin | Software | 113 | 01-01-2006 12:40 AM |
