View Poll Results: Which free or low cost hull modeling program(s) do you use?
Bearboat 3 1.72%
BioDesign 1 0.57%
BoatExpress 4 2.30%
Carene 1 0.57%
Carlson Design Hull Designer 5 2.87%
Free!Ship 58 33.33%
Free!Ship Plus 40 22.99%
DELFTship free 30 17.24%
HullCAO 2 1.15%
Hull Form Free Version 3 1.72%
PolyCAD 3 1.72%
jSDN 3 1.72%
Other (please post below) 21 12.07%
Voters: 174. You may not vote on this poll
Closed Thread
  #76
Old 02-01-2010, 11:24 AM
Fanie's Avatar
Fanie Fanie is online now
Fanie
Rep: 1930 Posts: 4,195
solidedge are offering their 2D component free
You can get the 2D here. You will have to fill in the thingy to get to the download area.
http://www.plm.automation.siemens.co...2d/index.shtml
If you're using something like Freeship then it is all you need. You can model the hull in Freeship, then export to Solid Edge and cad it up to have the pieces made.
I have a 3D Solid Edge, but the 3D I use very seldom. 99.99% is 2D.
As I understand this 2D is as professional as any out there, so do not think because it is 'free' it is not good, it is professional, just not 3D.
Solid Edge works quite easy too.
Regards
Fanie
Water ! Just gimme water !
  #77
Old 02-01-2010, 11:46 AM
nukisen's Avatar
nukisen nukisen is offline
Rep: 114 Posts: 380
Thanks I will run away to get this one imediately.
The more I learn the more I do understand that I do not understand. :)
  #78
Old 02-11-2010, 01:11 AM
nukisen's Avatar
Rep: 114 Posts: 380
Worked very fine!
Thanks a lot for the suggestion!
  #79
Old 02-11-2010, 11:45 AM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
The 2D functionality in SolidEdge is more than adequate for most purposes.
My only beef with SolidEdge is one of their restrictions on the academic version- anything created or edited by a copy running under an academic/educational licence gets locked in such a way that the commercially licensed version can't read it anymore.
  #80
Old 06-14-2010, 04:11 AM
Vulkyn's Avatar
Vulkyn Vulkyn is offline
Rep: 529 Posts: 486
I got confused with the similarities between DELFT ship and freeship. Are they the same or different versions?
They even have the same interface and icons ....
Apex said they are basically the same ..... are they both being updated or should i just stick with freeship ? (they cant read each other's files not sure if i exported properly though :S)
  #81
Old 06-14-2010, 04:34 AM
Fanie's Avatar
Fanie
Both are free - Download both and play with them.
I used to use Delftship before then switched to Freeship. Only reason is Freeship has a diffent resistance calculator available.
Regards
Fanie
  #82
Old 06-14-2010, 08:53 AM
marshmat's Avatar
The original Free!ship forked. Martijn (the original developer) decided to go after the pro/commercial market and renamed that branch Delftship and added a bunch of modules for common tasks in commercial naval architecture. It has a free version that is pretty much the same as older Free!ship versions, and a pro version that can use the powerful NA calculation modules. Free!ship Plus was then spun off by Victor, who has added some resistance prediction codes and other interesting tidbits; this fork is still FOSS and seems to be aimed more at hobbyists and backyard builders.
  #83
Old 06-14-2010, 09:11 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
cheers ill stick to freeship then !
  #84
Old 06-14-2010, 10:45 AM
Fanie's Avatar
Fanie
Eh Matt, whatch it with the 'backyard' there eh
I'm so glad my build will be in the front...
Regards
Fanie
  #85
Old 06-14-2010, 10:54 AM
Fanie's Avatar
Fanie
Eh Vulkyn,
I read somewhere you guys is Egypt only sail downwind... Is this true
Regards
Fanie
  #86
Old 06-14-2010, 11:55 AM
Vulkyn's Avatar
Rep: 529 Posts: 486
Depends on the wind
  #87
Old 06-15-2010, 05:25 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
I think they sail downwind upstream (south) and then drift downstram (north)
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
  #88
Old 06-15-2010, 05:50 AM
Raggi_Thor's Avatar
Fanie, do they ave the same user interface and modelling capabilities, Freeship and Delftship?
btw, I think 178Euros is "low cost" of you need some of the features in Delftship Pro.
I even think Rhino at 900(?)Euros is low cost compared to AutoCAD for example.
I think any tool is low cost if it pays back on one project, so you can buy it when you need it.
www.MBOATS.no
  #89
Old 06-15-2010, 03:23 PM
Vulkyn's Avatar
Rep: 529 Posts: 486
What exactly do you mean ??
River, Red Sea or Mediterranean or something completely different ??
  #90
Old 06-15-2010, 03:30 PM
Fanie's Avatar
Fanie
He's just pulling your leg, that means joking with you. In ancient times no one could sail upwind, so you'd sail upstream and drift back downstream
Regards
Fanie
Closed Thread
Best Marine Design Software for Hull Modeling? (2010) Admin Software 55 01-09-2011 11:36 PM
Free/Low cost software that accepts a table of offsets servobot Software 1 11-30-2008 09:36 PM
Best Free or Low Cost Marine Design Software? (2007) Admin Software 42 04-08-2008 04:15 AM
Best Free or Low Cost Marine Design Software? (2006) Admin Software 24 01-01-2007 03:00 AM
Best Free or Low Cost Marine Design Software? (2001-2005) Admin Software 52 01-01-2006 12:40 AM
