| AutoShip with winXP Hello! Just found this forum - looks very interesting, I'll be regular! I've just tried to install AutoShip v.8 on a PC with wiXP as OS - but have problems with the VB5-applications. ('...please upgrade to latest service pack of windows NT....') I'm aware that ASC states compliance with only win2k, NT, and 9x - but XP should be as common as NT in the trade nowadays, so I wonder if anyone knows a way to install the complete package on XP. Any tips would be appreciated. P-Wolff |
| Dear Mr. Wolff; The installer for Autoship 8 was written some years before Windows XP appeared, consequently, it recognizes XP as NT. Since that installer is programmed to install only on NT with service Pack 5 or higher, XP with little or no service packs fails the test. The only option is to update to a newer release of Autoship. The currently shipping release is 8.2. rossm@autoship.com, or sales@autoship.com, is probably the best contact for purchasing an upgrade. Hope this is of help. |
| XP has the option of running any software that requires older versions of Windows. I have some software that XP mimics 95 to run. One of the more savvy computer guys should be able to help you. Otherwise I could find the instructions again. Gary ![]() |
| I had a similar problem with a old AutoCAD. Try using the "Program Compatibility Wizard" in the Accessories. Help will guild you through it. Good Luck Colin |
| Thanks Colin, That's what I was trying to say but didn't have the right terms. Gary ![]() |
| Colin & Gary: thanks for tips, but as i'm not even allowed to install the vb5-applications due to 'wrong os', i have no option of using the compability wizard either. guess i have to go for v8.2 or maybe maxsurf or rhino as they do very well on the poll. as i understand one of the guys behind maxsurf is a regular on this forum - it gives them an advantage from my point of view p-wolff |
| The compability wizard will install the program for you and then open it in the correct OS. Gary ![]() |
| Gary - you are a true friend for a computer newbie! (I wanted to add a lot of smilies here, but i don't now how to do it ........) Thank you - it worked out nicely! p-w |
| Exporting from autoship to modelmaker | Bassoom | Software | 5 | 06-02-2005 10:51 AM |
| surface trimming in Maxsurf, NavalDesigner and or Autoship | innomare | Software | 5 | 02-14-2005 07:16 PM |
| Problems with creating an offset file with autoship | koen | Software | 2 | 08-06-2004 03:37 PM |
| Rhino3 & AutoShip problems | Unregistered | Software | 1 | 01-16-2004 12:33 PM |
| Press Release: Autoship LPS-Bulk | boatdesignnet | Press Releases | 0 | 06-06-2003 03:35 AM |
