Old 06-23-2008, 01:14 AM
brissyben brissyben is offline
Rep: 10 Posts: 11
Autoship IGS
Hi,
I am currently learning autoship, however I am most interested in converting files some one has already created in autoship, to an igs so I can use it in maxsurf, which I am familar with.
I have tried simpley opening the files and selecting the required surfaces (ctrl a) then I select from the menu toolbar, export - igs and then I choose the location where it will be saved. When I have selected the location I press save and nothing happens. I have to press cancel to escape the save dialog box.
can any one please give me some steps to a simlple method on how to save an autoship file as an igs,
thanks for any help you can give me
Ben
Old 07-17-2008, 03:37 AM
stavrou2000 stavrou2000 is offline
Rep: 10 Posts: 24
Hi bien
Look i have the same problem as you...i am user on Maxsurf many years and in the office that i work for at the present time they use Autoship.So if i find any solution to the above i will notify you.
Regards
Haris
freeship export igs? bbsboat Software 0 10-05-2007 09:30 PM
Thinkdesign to IGS fede Software 2 07-03-2007 08:00 AM
Autoship Tim_Hastie Marketplace 1 08-10-2006 09:22 PM
Autoship Negroo Software 1 04-05-2006 09:02 PM
New using Autoship ivansalasj Software 1 08-19-2004 01:17 PM
