Old 07-07-2007, 09:54 AM
yacht picasso's Avatar
yacht picasso yacht picasso is offline
Rep: 17 Posts: 45
autoship files to maxsurf
good day to all,
is there a way to export files out of Autoship and into Maxsurf?
Old 07-07-2007, 10:59 AM
CGN CGN is offline
Rep: 138 Posts: 547
Iges, could be a way to go.
Old 07-07-2007, 11:12 AM
Rep: 17 Posts: 45
i tried it but it doesnt seem to work.
is the iges format a standard? in that case i think i am doing something wrong!
Old 07-07-2007, 01:20 PM
CGN CGN is offline
Rep: 138 Posts: 547
why go to maxsurf if you have autoship?, to use hydromax?, if that is the situation isn't better to model the hull on maxurf and have a clean file?.
try this....if you have rhino use rhino to go from autoship to maxsurf...iges from autoship to rhino to maxsurf, or download Moi3D is free for now, and open your iges file from autoship (or just try to see if it reads it) and then resave as a 3DM and try maxsurf again, if not, save it as an iges from Moi3D and see if maxsurf reads the file, but i think your best way is to remodel in maxsurf.
Old 07-07-2007, 02:53 PM
Rep: 17 Posts: 45
yes, i wanted to try hydromax!
i'll do as you advise.... thanx a lot!
Old 07-08-2007, 12:56 PM
Rep: 17 Posts: 45
WOW man..... MoI3d is a hell of a good user friendly program!!
Thanks for the TIP!!!!! ))
ps. alas, maxsurf still doesnt read it. I've given up!
Old 07-08-2007, 07:39 PM
CGN CGN is offline
Rep: 138 Posts: 547
Good, I mean if you are going to use Hydromax why bother with other application?..or maybe use something like .Gf (GHS) to read it into hydromax maybe will work.
Just as a comment i done it before and i'm 100% sure Maxsurf reads properly iges files.
cheers
Old 07-09-2007, 09:28 AM
petlily petlily is offline
Rep: 10 Posts: 29
I tried it just now. Seems to be working perfectly for me. The only thing matter is when A'ship asks to split the object at corners which will eventually result many surfaces to appear at Maxsurf especially if your model has many corners such as on a hard chine boat. But that can be easily solved with bonding the surface edges. Anyway, the best way to run stability checks from a .pr3 file (A'ship) is always to export directly into Autohydro i.e. the .gf file. Bear in mind that .gf files can be read directly either with Autohydro or GHS. They only differ slightly with the run (Macro) files.
Old 07-09-2007, 10:09 AM
Rep: 17 Posts: 45
thank you V V much!!
Maxsurf or Autoship deej Software 17 05-26-2009 02:55 AM
surface trimming in Maxsurf, NavalDesigner and or Autoship innomare Software 5 02-14-2005 07:16 PM
autoship to maxsurf hello Software 4 08-02-2004 01:17 AM
Maxsurf VS Autoship christos Software 3 02-19-2002 10:51 AM
