| Autoship to AutoCAD - how to create a DXF Hello all, I'm a marine engineering student and I'm writing my final project which consits on designing a fishing boat. The thing is that I already developed the hull in Autoship, but when I try to create the DXF in order to edit the plan in AutoCAD I get some crazy thing. I think this is because of the settings, I'm trying everything but I don't get it right. So this is what I do: 1. I choose the group that forms the surface of the hull. 2. I choose Export in DXF. 3. I try some settings in the dialog box. 4. I create the document in DXF. 5. I get something very weird in AutoCAD. So I attached an image that shows the dialog box with the settings I chose and the resulting image I get in AutoCAD. Thank you very much in advance. |
| uncheck the Frames, All views , see what happen.. need to check the autoship design too.
__________________ DAre To DreAm |
| I tried that and nothing. I uploaded the autoship design I hope there is more luck this time, thank you very much anyway. |
| check if that work for you. version 9.2 work good with your file. exported normally without changing any settings.
| Thank you very much, it finally works. Did you do something special? I still don't get what was working wrong. |
| no . i did nothing special. may be its problem with ur version or license. i dont know.
| Thank you zeroname, I solved the problem, and it was the units, that I had meters as outcome unit and it has to be mm so it doesn't go crazy. Thanks again you have helped me a lot. See you in the forums!! |
| PDF to DXF | ThomD | Software | 6 | 10-15-2010 07:52 PM |
| Cannot create offsets in Maxsurf Academic... | mystrwizard | Software | 1 | 11-29-2009 03:47 PM |
| create a cleaner Rhino Shape? | Grant Nelson | Software | 3 | 12-26-2007 03:17 PM |
| from drawing to dxf | jonnyb | Software | 23 | 11-16-2007 02:35 PM |
| How do I create a decent yacht design brief | 2020 | Boat Design | 14 | 08-23-2006 06:57 PM |
