Old 01-27-2012, 03:39 AM
J Feenstra J Feenstra is offline
Rep: 42 Posts: 42
automation in maxsurf academic
Hello!
I'm building an excel sheet to merge the Savitsky planning hull resistance calculations and the initial hull design. My goal is to create a “push of a button” tool for the intial hull design, so I can create several hull designs in a short amount of time. My questing is rather simple, is automation possible for maxsurf academic? ? I’m asking this because simple commands, like new design, are disabled in my version.
Old 02-19-2012, 09:22 PM
formsys formsys is offline
formsys
Rep: 37 Posts: 73
Yes you can use Automation with the academic version of Maxsurf. If the New Design command is grayed out it just means you already have a blank design and you can start adding surfaces.
Old 02-20-2012, 12:51 PM
b1ck0's Avatar
b1ck0 b1ck0 is offline
Rep: 28 Posts: 86
Another option might be using Friendship Framework .. / they have free student licences /
Old 02-21-2012, 02:10 AM
Rep: 42 Posts: 42
If I say I like maxsurf more, does that mean I get a free version of maxsurf ultimate?
but im trying to merge several calculations in one sheet, like Blount and fox, initial stability calculations via excel.
Thanks for the reply
Cannot create offsets in Maxsurf Academic... mystrwizard Software 1 11-29-2009 03:47 PM
Asymmetrical hull using Maxsurf Academic? mystrwizard Software 3 11-22-2009 05:58 PM
Maxsurf Academic Andrew Mason Software 34 04-06-2005 08:42 PM
Maxsurf Academic guest account Andrew Mason Software 0 05-25-2004 12:21 AM
