Old 08-20-2008, 12:18 AM
bobg3723 bobg3723 is offline
Rep: 78 Posts: 278
Autolisp meshing routines for Carlson Hull Designer
Hello everyone,
This should read: Autolisp routines for IntelliCAD to mesh a 3D hull from a Carlson Hull Designer 2D lines plan, to be exact.
I've written these hull meshing routines in the hopes that those using IntelliCAD can now avail themselves to a suite of semi-automated scripts that will create a 3D meshed hull using the 2D lines plans created with Carlson Hard Chine Designer.
You'll have to copy the TXT files into the clipboard and then paste them into your Lisp editor to be saved as a .LSP file before loading them into Intellicad.
Enjoy!
BobG
Old 08-21-2008, 02:15 AM
Rep: 78 Posts: 278
In the txt file FITUP.TXT, I failed to mention that you also need to load the third application named MODIFY.LSP. That file contains the function '3DFIT'.
I've also re-edited the 'Meshing a hul.doc' to be a little clearer on how and what instance to use '3DFIT'.
If anybody's using these applications inside AutoCAD, please let me know if there are any bugs for me to correct.
Cheers,
BobG
Last edited by bobg3723 : 08-21-2008 at 05:12 AM. Reason: revision in text of 'Meshing a hul.doc'.
Hull Designer wanted mrbaseballny Services & Employment 9 07-17-2005 10:00 PM
Carlson Hull Designer problems Garrett Software 6 11-01-2004 08:09 AM
Fit of panels from Carlson Hull Design? BCBoater Boatbuilding 2 08-27-2003 05:52 PM
Stepped Hull Designer for evaluation of hull lpsco1 Powerboats 2 08-18-2002 08:21 PM
Carlson Design Hull Designer Matthew Software 1 06-20-2002 11:23 AM
