Old 12-14-2009, 06:00 AM
hild hild is offline
Autohydro - maxVCG and draft dependent limits
I have a problem to apply the following stability criteria (old deterministic damage criteria for passenger ships) SOLAS Ch. II-1 Reg 8 2.3.3:
"A residual righting lever is to be obtained within the range of positive stability, as calculated by the formula:
GZ = (pax. heeling moment)/(displacement) + 0.04" the variable here is the displacement (intact disp).
Question: How to apply a draft dependent limitation in autohydro when creating a maxvcg limit curve for a damage condition? e.g.
maxVCG draft 1.8,1.9,...,2.6 /trim:0
I don't want to run a maxVCG command for each draft (separate output for each draft). Tried to use /composite and variables without success.
Any ideas?
/Hild
Old 04-13-2010, 07:44 PM
eabrenio eabrenio is offline
Rep: 10 Posts: 4
Edit this one in your model data
clear report
report header MAXVCG.RUN
report footer Autohydro 5.1.0 &C&D,&T &R&P of &N
status
limit off
limit area:degrees
limit area from 0 to 30 > 10.34
angles 0,5,...,40
maxvcg draft 0.5,0.75,1,...,4/LCG:5.63A/ShowRa
email:eabrenio@hermashipyard.com
Old 04-14-2010, 11:09 AM
Paul Kotzebue's Avatar
Paul Kotzebue Paul Kotzebue is offline
Rep: 272 Posts: 244
What is the LIMIT command you used to define the above criteria? Or is that what you're asking for?
Paul R. Kotzebue, PE
www.pkboatplans.com
Earth population 'exceeds limits' RHP Open Discussion: All Things Boats & Boating 45 04-15-2009 03:41 PM
twin keel 2' draft instead of single 7' draft on 65' yhxaig Projects & Proposals 3 11-12-2006 05:25 PM
Grain runout limits nero Materials 1 04-24-2005 12:30 PM
Sheathed strip - Limits? Mohan Pakkurti Wooden Boat Building and Restoration 1 01-24-2005 10:01 AM
Speed Limits Coming??? sharkeymarine Powerboats 12 03-06-2003 10:48 PM
