Old 04-11-2008, 11:09 AM
Scottg4001 Scottg4001 is offline
Rep: 10 Posts: 11
AutoDesk Inventor 2009 Question!!!
I am currently working for my dad. We use a 3D CAD program, Alibre, for design work for our products. My father knowing that I am enrolled at Westlawn knows that I need AutoCAD LT or AutoCAD 2009, but both of those programs are not capable of doing 3D assemblies like Alibre does. AutoCAD Inventor does, but I am wondering if I can design the yachts needed for Westlawn on Inventor or do I need AutoCAD? Hopefully there is someone out there with expierence in Inventor and I hope this question is clear.
Thanks Ahead of time,
Scott
Old 04-11-2008, 12:52 PM
Rep: 10 Posts: 11
Nevermind
I just found out the answer I was looking for.
Old 04-12-2008, 06:00 AM
DavidJ DavidJ is offline
Rep: 433 Posts: 151
I don't know very much about Alibre, but if it lets you make 2D drawings and export as dwf, dxf, or dwgs, you probably don't need autocad. Also I believe inventor still requires autocad to work in 2D, so you can't avoid buying it to make proper 2D drawings.
For anyone doing something like Westlawn I would recommend just getting Rhino. While it isn't the best piece of software for doing everything, however, it is the best for some things, it can do a little of everything else, and the price is right.
Old 04-12-2008, 10:00 AM
alidesigner alidesigner is offline
Rep: 93 Posts: 171
As I understand it if you buy Inventor you get Autocad included, but if Alibre is working for you then just stay with that. Alibre is a cheaper competitor to Inventor, Solidworks, Solid Edge, Pro E etc. I'm sure its is dwg compatible.
Old 04-12-2008, 01:33 PM
pulsar pulsar is offline
Mechanical engineer
Rep: 30 Posts: 32
Inventor allows create 2d Drawings as file *.idw and *.dwg. There isn't necessery to have Autocad ( but I think it's included to Inventor Package).
It's quite good to make assemblies and other staff, but it isn't good program to design hulls.
If you have any questions regarding Inventor, just write
Regads
AutoCad, Inventor, CADKey Fibertron Software 4 01-18-2005 09:54 AM
Autodesk Inventor Arrowmarine Boat Design 2 01-05-2005 06:30 AM
Autocad Lt 2002 vs. Inventor 5 BoatInventor Software 2 11-25-2004 06:49 AM
parametric 3-d-modelling -> AUTOdESK INVENTOR 5 User_U Software 5 03-10-2002 12:59 PM
Autodesk Inventor? Archive Software 1 06-12-2001 03:48 AM
