Old 05-23-2005, 01:36 AM
Leron Leron is offline
Rep: 10 Posts: 14
Autocad-Rhino-Hydromax?
hello everyone. I'm a new member.
Please excuse my bad english.
I have autocad 2005 and hydromax 9.52, and i need to do some hydrostatics calculations, but my problem is exporting dxf files into hydromax(or maxsurf), the autocad's dxf files just appear as markers in maxsurf, and i realize that dxf files don't works correctly into maxsurf, just as reference points(markers).
My question is, if exporting autocad's dxf files to rhino, and then rhino (iges) to maxsurf will works?.
If works, can I export a 3D view into rhino, and if rhino will give me the additional views (plan, body plan, profile)?. or which method is better (exporting each section from autocad to rhino?).
thanks for your reply.
Old 05-23-2005, 04:23 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
Many programs prefer older file versions, like DXF from AutoCAD 2000 or R14.
I think it's a good idea to first import to Rhino, then rebuild all surfaces and export to Iges.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 05-23-2005, 05:11 PM
Rep: 10 Posts: 14
thanks
Then my assumptions are correct.
Can you teel me wich method is best?:
-Exporting the entire hull surface (3D view) from autocad to rhino.
-Exporting each section from autocad to rhino, and then modelate the surface in rhino.
Old 05-24-2005, 03:45 AM
Raggi_Thor's Avatar
If the hull surface is modelled in AutoCAD it's difficult to know how fair it is, you can have a quite unfair surface that looks good on the screen. Then it will be best to export the sections to Rhino and use the loft command. You can also create some longitudinal curves in Rhino and check their curvature and adjust before you loft.
www.MBOATS.no
Old 05-24-2005, 09:31 AM
Rep: 206 Posts: 391
Raggi is correct, you need surfaces for hydromax, not DXF points or wireframes. The surfaces can be generated in Rhino or Maxsurf, but need to be written from Maxsurf as a Maxsurf design file to read into Hydromax.
Andrew Mason
Formsys
http://www.formsys.com
Maxsurf Academic
Old 06-02-2005, 09:27 AM
archnav.de's Avatar
archnav.de archnav.de is offline
Rep: 60 Posts: 208
First question: Is, the AutoCAD surface a real freeform surface? 3D-DXF is not a surface or solid format. Try to save it as ACIS. Than look at the file in AutoCAD again. Insert ACIS, if you can see the surface now, then I can give you a hint how to manage the interface between Rhino and AutoCAD in a propper way.
Save the file in AutoCAD as ACIS, then go to steptools.com convert the file with the free service into .stp and import the file into Rhino.
If you can't save the file as ACIS then your file it is not a real surface.
Old 06-06-2005, 10:23 PM
hasicktear hasicktear is offline
Rep: 10 Posts: 13
That's very hard. there isn't any simple way to convert dxf meshes to iges. Rhino has a command that converts a meshed model into iges but it converts each meshes on the meshed model to an iges surface.. Eventually there will be lots of iges surface and maxsurf will be forced.
Command : meshtonurb
I offer export all of the sections to rhino and then regenerate the hull shape in rhino.
Old 06-07-2005, 04:23 PM
DaveB DaveB is offline
Rep: 11 Posts: 128
sections to hydromax
Dear Andrew,
I was under the impression that there was some way to input sections into hydromax from offsets, much like those used by GHS... Is this so? Was there ever such a utility?
I thought it was the kind of thing that you could do by cleaning up data in excel and then pasting into a table in hydromax.
Best regards,
Dave
Old 06-10-2005, 11:41 AM
Rep: 10 Posts: 14
thanks
thank for your replies.
Now I'm working with maxsurf and I have obtained good results, now I'm satisfied.
Rhino is a very good software, but I underestimated Maxsurf capabilities. I was search for a fast way to translate a surface into Maxsurf without working with it.
Thanks again.
Old 06-14-2005, 03:20 PM
Rep: 206 Posts: 391
DaveB
Hydromax only works from surfaces at the moment which gives very good accuracy as there is no need to approximate the shape of the hull between offset stations and allows us to use very large numbers of sections where necessary to calculate the hydros.
We are working on adding input of offsets at the moment to satisfy those situations where a full surface model is not available, but we would like to do this in a way that does not compromise the accuracy of the calculations. This is not a trivial problem.
regards
Andrew
Andrew Mason
Formsys
Maxsurf Academic
Old 06-16-2005, 12:01 AM
Rep: 10 Posts: 14
Maxsurf
I hope Mr Andrew replies me.
As I said above I'm satisfied with maxsurf but i don't have much practice with it.
I would like to know if you can tell me some links for tutorial of Maxsurf since the tutorial of maxsurf are very poor (for people like me that known the elemental tool of the software), I've been found tutorial about the creation of surfaces like bow shape but I can't find it.
is there any tutorial step by step about the design for a full ship or any procedure to do that, like "create a bulbous ship" or " step by step multihull surfaces", etc
another question, if there is no problem Mr Andrew. How read Hydromax the surfaces?, i.e., how Hydromax read the transom?, in the hydromax samples (folder by default) the ship doesn't have a transom, Hydromax assumes that there is a transom, is relevant to put it?
thanks for your attention and reply.
Regards
Leonardo Pérez
Old 06-16-2005, 04:05 AM
Rep: 206 Posts: 391
Leonardo
We do not have a tutorial for putting together a full ship but I may do this when I return to my office (I'm on vacation at the moment). There is a tutorial for doing a multihull however.
Regarding the transom in Hydromax, it is not necessary as Hydromax does its integration using transverse sections through the hull. Unless the transom is sloping or curved it is not necessary to close off the aft end of the hull.
regards
Andrew
Andrew Mason
Formsys
Maxsurf Academic
Old 06-16-2005, 05:38 AM
archnav.de's Avatar
Rep: 60 Posts: 208
Dear Andrew,
What are the exact interface possibilities for Hydromax? We don't like .igs for a lot of reasons.
We prefer Parasolid (.x_t) Acis (.sat) and Step (AP214). If you have this three formats availabele, you can act with this files in most 3CAD-Systems like native files.
Cheers
Bernd
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 02:55 AM
Rhino 3 to AutoCAD Mechanical Desktop 4 (XchangeWorks?) BillyDoc Software 9 06-02-2005 08:25 AM
Importing and exporting between Rhino 3.0 and Autocad 2004 Coen Software 4 03-01-2005 09:27 AM
Rhino <-> AutoCAD conversation Tobias Software 3 08-14-2004 11:34 AM
How to import solids created in AutoCAD to Rhino? Tobias Software 5 08-05-2004 11:29 AM
