Old 12-20-2011, 02:24 AM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Auto update sections in Rhino
Is there a way of making it so that section lines - sections, buttocks, etc - will automatically update as you alter their parent surface in Rhino?
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 12-20-2011, 03:55 AM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
I'm affraid Rhino is not a parametric software, like Solidworks or UGS NX. However, it has the "Record history" option, which might help you. See this video here: http://designreform.net/2008/05/rhin...-along-surface It has also taught me the usage of "Flow along surface" tool, very handy for some tasks.
Cheers
Old 12-20-2011, 04:02 AM
Thanks D... I rather figured that I already knew the answer... was just hoping someone had a trick....
Will
www.imaginocean.net
Old 12-20-2011, 04:11 AM
daiquiri's Avatar
It looks like Grasshopper plugin gives the possibility of parametric modelling to Rhino too: http://www.grasshopper3d.com/
Think I'll give it a try.
Cheers!
Old 12-20-2011, 04:16 AM
...hmm... that might be worth a look....
I don't normally do my hull surface modelling in Rhino,but was just messing about... thanks again...
Will
www.imaginocean.net
Old 12-20-2011, 08:44 AM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Another possibility (which I haven't tried) would be a simple script to create the lines, and then run the script when ever you wish to update the lines. Put the lines on a separate set of layers, have the script delete them, then run Contour to create a new set of lines.
David Cockey
Old 12-20-2011, 04:35 PM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
Will the method that I outlines in Yacht design in Rhinoceros 4 post 33 can also be used in a static form. By putting in a series of planes for sections, waterlines, etc. do the history/ intersection for each, then put the planes on a separate layer so you can turn them off, leaving the intersection line which will move with the surface. You can also put the lines on their own layers so you can turn them on and off.
Old 12-20-2011, 06:37 PM
Aha!!... see.... that's what I love about this place.... there's always someone around smarter than me
Will
www.imaginocean.net
Old 12-20-2011, 07:40 PM
Engineer
Thanks for the reminder.
David Cockey
Old 12-20-2011, 11:30 PM
Rep: 547 Posts: 540
There is another method where you can use the “symmetry command to mirror the half hull being used to edit. If you then put a plane like the others through this, to get say waterlines, then hide the plane and the new hull side on layers, you then can have sections on one side and waterlines on the other all up dating when you move the control points on the original hull. There is one small limitation to this after symmetry on the original , the first control point after the centre line tends to want to have a tangent type relationship with its opposite which limits what you can do with it. I found if I snapped these control points to their centreline point, making them redundant , then add another row control points after them gives you back control.
Old 01-03-2012, 04:38 AM
RhinoParametric RhinoParametric is offline
Rep: 10 Posts: 5
Hi,
you could have a look on RhinoParametrics plugin for Rhino 4 which gives you the same range of functions as classical parametric cad software.
www.rhinoparametrics.com
Old 01-06-2012, 06:04 PM
ABoatGuy ABoatGuy is offline
Member
Rep: 79 Posts: 192
Rhino Marine does it. Costs a few dollars but worth it.
Old 01-06-2012, 11:20 PM
Engineer
RhinoMarine has been replaced by Orca3D www.orca3d.com
David Cockey
Rhino Rhino Rhino (hull thickness, offset surface, and unrolldvp for cnc cutting) metin_mehel Software 11 10-11-2011 12:10 AM
NACA Sections landmarine Boat Design 42 03-31-2010 06:24 PM
aluminium sections Guest62110524 Materials 0 02-14-2010 09:23 PM
Aluminium Sections Guest62110524 Marketplace 0 02-14-2010 08:28 PM
pulling station sections out in rhino lazeyjack Software 3 07-23-2007 09:57 PM
