Old 11-25-2009, 09:52 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
attaching GHS data in Rhino
I really struggle to attach GHS data for a hull which has several surfaces which are not able to be joined.
For example when i want to attach Hull part i have to select each part one by one and for some cases it becomes a great trouble.
Is there any way to select the all surfaces in one selection?
Thanks
Md. Al-Amin Pavel
http://www.paveldesign.tk
"A question that sometimes drives me hazy, am i or are the others crazy?"
Albert Einstein
Old 11-25-2009, 11:46 AM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
Go to HELP, SELECTION, there's a tool for that.
"The hand feeds the mind."
Weston Farmer
Old 11-25-2009, 07:00 PM
pavel915's Avatar
Rep: 154 Posts: 319
i have gone through the "AttachGHSData " in help menu. I can attach GHS data for hulls with very few or one surfaces. But i am facing problem for the hulls which have many surfaces. In that case i have to select surfaces one by one and some timse it becomes a real trouble.
Md. Al-Amin Pavel
Albert Einstein
Old 11-25-2009, 10:06 PM
ABoatGuy ABoatGuy is offline
Member
Rep: 79 Posts: 192
My best results have come using a half hull model. Then join all the surfaces. If the model is reasonably good that should work and usually makes a decent GF file. This has worked on some fairly complex hulls and decks. You should still go through it station by station to make sure it is clean.
Sometimes there is a quirk in the GF file. The software often makes the forward station with two points. I believe the GF file format calls for three. It will throw off the overall length which screws up some of the ratios (L/B etc.), but it is easy to fix. I'm working in AutoHydro, I'm not sure if GHS is this picky.
Export Rhino Data to Excel... jamesflett Software 5 09-06-2009 01:18 PM
Michlet Offsets from Rhino or GHS? gdmw Software 24 09-04-2008 10:12 AM
rhino/righting arm data 3dig Software 7 05-03-2007 03:09 PM
rhino3d 2.0 ghs data export pavel915 Software 9 12-09-2006 10:29 AM
exporting GHS data from Rhino3d version 2.0 pavel915 Software 4 12-06-2006 04:01 PM
