Old 11-21-2009, 09:19 PM
mystrwizard mystrwizard is offline
Rep: 10 Posts: 5
Asymmetrical hull using Maxsurf Academic?
I am designing a Proa hull and actually have all the marks in representing offsets for the hull but I cannot figure out how to fair the lines to match up to one of the sides. When I fair one side, it just mirrors the other and I cannot figure out how to be able to fair each side separately.
Old 11-21-2009, 10:58 PM
bhnautika bhnautika is offline
Rep: 547 Posts: 540
Mystrwizard maxsurf starts by assuming an asymmetric hull form you can turn this off in the “surface properties “ then you have to create the new surface or surfaces for that side of the hull. It’s a good idea to bond the edges on the centreline.
Old 11-22-2009, 10:32 AM
Rep: 10 Posts: 5
So I went into surface properties and turned off symmetrical but now cannot figure out how to create a new surface for that second side. Ive tried to flip surface but it seems no matter which option I use, it flips in the wrong way? Any suggestions? Thanks!
Old 11-22-2009, 05:58 PM
Rep: 547 Posts: 540
Mystrwizard I ran the steps like this from turning off symmetry, in section view I went to surfaces> flip surfaces> in dialogue box, select all, then pick transverse, figure zero, then tick duplicate and bonding if necessary, ok. It put in a surface opposite which I then bonded.
Maxsurf Academic Design Contest! Andrew Mason Boat Design 1 06-17-2010 08:24 AM
after having a dxf file from maxsurf academic pavel915 Software 0 11-26-2006 08:37 AM
Maxsurf Academic Andrew Mason Software 34 04-06-2005 08:42 PM
Maxsurf Academic Design Contest! Andrew Mason Software 0 11-12-2004 06:08 AM
Maxsurf Academic guest account Andrew Mason Software 0 05-25-2004 12:21 AM
