| Assigning Thickness to Rhino Model I am trying to print my model out on a 3 D printer and would like to assign some thickness to the model itself in Rhino. I am not sure if this is possible since Rhino is a surface model program and not a solid model program. Please let me know if I can some how make this surfaces solid or at least give them some thickness. Scott |
| offset surface Did you try offset surface with "solid" option? |
| whilst your on Rhino Sparks Can you tell me, , I go unrap a surface, and it just sits there 'calculating moments" nothing happens>? help please |
| Rhino release. Which version are you using? I know from Rhino3 sr3 some developable plate issues have been solved. |
| V 20 aug 2001 |
| plate to be developed Just guessing from here: You can try alter the shape a bit, perhaps than this bug does not occur. Is the plate very twisted? |
| not really, its upper chine pl, on chine yacht, so I spose does have heaps wrap |
| Hmmm....... I'm out of suggestions. |
| 2D Rhino to Autocad export and rhino sectioning | fede | Software | 13 | 10-18-2009 02:55 AM |
| Skin thickness | bearwen | Fiberglass and Composite Boat Building | 12 | 01-11-2006 09:38 AM |
| 3D Rhino model and 2D drawings | signum | Software | 2 | 08-19-2005 06:35 AM |
| Surface thickness - in Rhino | Willallison | Software | 6 | 11-30-2003 04:34 PM |
| Foam thickness | Guest | Materials | 3 | 08-06-2003 04:40 PM |
