Old 10-05-2010, 08:58 AM
Stuhl Stuhl is offline
Rep: 10 Posts: 7
ask for some help
I joined a team to build a concrete canoe, but my major is material and don't know much about design ,so I need some help
if anybody can tell me which software is better for me to use ,not too complex ,because I have to learn it in a month
thank you ~~~
Old 10-05-2010, 09:10 AM
pavel915's Avatar
pavel915 pavel915 is offline
Rep: 154 Posts: 319
Freeship, it is free and easy,,,
Md. Al-Amin Pavel
http://www.paveldesign.tk
"A question that sometimes drives me hazy, am i or are the others crazy?"
Albert Einstein
Old 10-05-2010, 09:13 AM
pavel915's Avatar
Rep: 154 Posts: 319
But I hope you are concerned about the fact that , learning boat design does not mean- learning a boat design software only. If you really mean "design" instead of "drawing" or "drafting" then you have to go through many theoretical study too,
Md. Al-Amin Pavel
Albert Einstein
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
You can try with Freeship, it is freeware and pretty easy to use and has incorporated all the stability and power prediction tools you need for a canoe.
http://freeship-plus.land.ru/downloadsE.html
you should first download and install the 3.1+ full version, and then the last update (3.15+)
Good luck!
P.S.
Pavel was faster than me...
Old 10-05-2010, 09:32 AM
Rep: 10 Posts: 7
I learn the software is just to help others to drawing ,I have to admit that I really know little about design
perhelps I should listen to your suggest and try to learn some theory ,maybe it will help me to use the tool better.thank you for your help
and hope you can understand my poor english
Old 10-05-2010, 09:40 AM
Rep: 10 Posts: 7
Good luck!
P.S.
I don't know why I can't link to the web you just gived,maybe I have to search for it somewhere else ,still thanks for your help!
Old 10-05-2010, 09:49 AM
daiquiri's Avatar
Try here for the 3.1+ full version:
http://depositfiles.com/en/files/nb79xzuwn
and here for the update to 3.15+:
http://depositfiles.com/en/files/xc07a6wbs
Old 10-05-2010, 10:19 AM
pavel915's Avatar
Rep: 154 Posts: 319
If you are new in design, you should first go through "hydrostatics", "stability","Resistance" etc. Anyone of the "team" who are designing the boat should have this theoretical knowledge.
For the basic understanding of the above topics you can read "Basic Ship Theory" Voule 1 and Volume 2 , this books are very good for introduction to the theoretical knowledge of ship/boat design,
Md. Al-Amin Pavel
Albert Einstein
Old 10-05-2010, 02:58 PM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
nothing wrong with joining a team, a canoe, freeship or making a design
first thing in my mind however was what theory you and your team are trying out
a canoe better be build from wood or plastic, alu or steel would allready be odd, but concrete is ridicules
concrete is used for bigger displacement or houseboats, not for canoes if you see my drift
Old 10-05-2010, 03:08 PM
thedutchtouch thedutchtouch is offline
Rep: 39 Posts: 90
concrete canoes are a common design challenge/competition, usually for college/university level students, although ive heard of some older and younger groups competing. The point of the challenge is to overcome exactly what you're alluding to- the fact that concrete isn't typically used in this way.
all i can add is if your concrete canoe cracks on the way to the event, duct tape should hold long enough to compete, but not long enough to bring it home in one piece. (had a friend that competed in undergrad)
Old 10-05-2010, 03:15 PM
yipster's Avatar
i see, did not know that and point at important concrete iron web than..
( and can think of other more apropriate design challenges for concrete )
Old 10-05-2010, 03:26 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Yah, like a submarine!!!!!!
Just kidding... ha, ha, ha...
-Tom
Old 10-05-2010, 03:32 PM
Petros Petros is offline
Rep: 889 Posts: 1,005
IF this is a collage engineering exercise or contest I would not get too elaborate on the actual hull shape. My own school participated in a similar project 30 years ago. I have since built over 12 kayaks and canoes and learned about hull design.
The most important design element is that your final hull weight and your crew weight is below the displacement capacity of your design. Make it as light as possible (very thin skin with wire mesh reinforcement), and your design will be fastest. Our school's entry was way too heavy, the hull failed under its own weight and never made it to the water. The lightest boat will be fastest.
Canoe and kayak shapes in general have less drag than most other shapes because of their fineness ratio (length to width). A round bottom will have less surface area but will not be stable, so make it with a fairly flat bottom. Find a canoe about the size you want and just copy the hull lines. Since even a thin walled canoe of concrete will weight a lot, you must make sure you have enough free-board to float the weight of the canoe and crew without taking on water over the sides. That is your most important design consideration.
Make it long and slim, make it as light as possible (thin walled yet still water tight), and make it so it can float itself and crew, and you will have the best one.
Good luck.
Old 10-09-2010, 11:48 PM
Rep: 10 Posts: 7
Is 'Basic Ship Theory' the book writen in english? it's a little difficult for me now , or i can find some books in similar
oh~~it's much more complex than i expected,also more interesting
Old 10-09-2010, 11:52 PM
Rep: 10 Posts: 7
we may use some glass fibre or something else
