| ask for help in maxsurf who can help me to fix this problem? Many thanks! |
| Maxsurf Problem Chaser, This looks like a continuation of your previous posts - yes? I think if you need some help then you will have to attach some more information to your posting. You need to include the following: Hull definition file - e.g. problemship.msd Compartment definition file - e.g. problemship.htk Load case file - e.g problemship.hml Damage case - e.g problemship.dcs Also provide the specific criteria you are working to e.g MCA, USCG etc. Regards, Graham Westbrook Naval Architect www.westbrookmarine.co.uk |
| Hydromax Problem chaser, Had a quick look at your files and the only number that is giving you problems is the port offset for the provisions (-0.874). Any value over about -0.7 is giving you the error you posted. Similarly if you change the heel and the downflood point to port for the stability analysis the error does not occur! I can only conclude that over -0.7 there is a hull definition clash, maybe this is something for you to check. Hope this helps. Graham Westbrook Naval Architect www.westbrookmarine.co.uk PS If I ever come to China you can buy me a beer. |
Thank you for your suggestion,i found the problem is deck eage in the stern,the postion is too lower,as i defined the stern part as a tank.wecome to china , i prepared several dozen of beer for you . |
| problem of maxsurf one more question ,i cant understand when i added spary rail on the original model,i found the sections aren't contious in the bow part. |
I am learning maxsurf right now ,i know you are very skill on it ,so i would like to ask you some questions,could you can help me,my email id is jack@iagyachts.com. |
| Maxsurf Learning Chaser, As we say'Flattery will get you anywhere', however I don't think I have the spare time to help you consistently so my best advice is to take a training course in Maxsurf/Hydromax etc. I see from your e-mail address you work for a large yacht builder and I think you should approach them to buy you some formal training. After all it will be to the benefit of everyone! Good Luck Graham Westbrook Naval Architect www.westbrookmarine.co.uk |
Thank you for your honesty, i suppose it is the last question,i know you are very busy everyday,because i must to fix this problem today,i should send the final calculation to Rina, so i ask for help to you , |
| Chaser If you hav problems such as this it is best to contact Formsys support directly, they are experts and can sort out such problems very quickly. Contact email is support@formsys.com
__________________ Andrew Mason Formsys http://www.formsys.com Maxsurf Academic http://www.formsys.com/academic/maxsurf/ |
| I want to install maxsurf/S program from maxsurf formation CD (version 11) but it is asking for a password to extract the attached file.I have no idea where can I get this password from . Please Help |
| try this: exclam8ion if not work, contact the person from whom u got the CD or mail formsys. |
| Maxsurf please HELP!! | lazeyjack | Software | 14 | 01-25-2012 01:32 AM |
| help with maxsurf | rob_fox | Software | 4 | 05-19-2008 10:55 PM |
| Maxsurf Help | TimClark | Software | 5 | 12-28-2005 12:03 PM |
| Maxsurf Q (AutoCad -to-Maxsurf) | cmcguinness | Software | 1 | 12-01-2004 05:00 PM |
| Maxsurf AE | fede | Software | 10 | 02-17-2004 08:22 PM |
