Old 01-24-2013, 10:53 PM
Rep: 1909 Posts: 1,748
Originally Posted by CWTeebs View Post
jehardiman: I had no idea AQWA produces pretty pictures, and I'm an expert in the tool!
? They had a visualizer back in 2007.
Anyway you are right about the highjack. I have a feeling this might be a case where the log is too big for the chainsaw and he will have to take an axe to it.
Old 01-25-2013, 07:26 AM
CWTeebs CWTeebs is offline
USCG 3AE
Rep: 171 Posts: 202
I guess it depends on what you mean by "pretty" pictures
And, agreed. I'm interested in other tools you may have found. Accurate codes exist, they just require, you know, super computers.
Old 02-07-2013, 09:06 PM
aparker aparker is offline
Naval Architect
Rep: 10 Posts: 7
Sorry for the very late response, but thanks for all of the help. This topic has gone on the back burner for me as I'm still trying to find realistic damping characteristics for the fenders in the system. Does anyone know how/where to find appropriate beta values to go with the fender stiffness?
Thanks
Old 02-08-2013, 11:13 AM
USCG 3AE
Rep: 171 Posts: 202
Hi Mr. Parker,
Attached is a datasheet from Yokohama fenders. The datasheet columns lists things like nominal size, internal pressure and reaction forces. With some engineering work these can be converted to the fender parameters used in AQWA.
http://www.anchormarinehouston.com/c...okohama-fender
Old 02-11-2013, 02:31 AM
Naval Architect
Rep: 10 Posts: 7
Thanks CWTeebs. Would you be able to elaborate slightly on those methods please?
Old 02-11-2013, 09:40 AM
USCG 3AE
Rep: 171 Posts: 202
I haven't actually used fenders on industrial projects, so not really. If I was, and was presented this datasheet and had nothing else, I might try building a capsule shape in Rhino3D to represent the fender, attach a few control points and 'compress' it, calculate the volume for each compressed state, then using perhaps ideal gas and the pneumatic datasheet I provided above calculate force values at each compression state. These could then possibly then be interpolated and converted to fender coefficients in AQWA. I don't have AQWA in front of me at the moment and frankly don't remember offhand data it requires.
Aqwa quadratic damping jmpape Software 6 04-23-2013 11:38 AM
Additional Silencing Willallison Sterndrives 8 07-26-2010 11:34 PM
Help Installing Matrix System David Cowen Fiberglass and Composite Boat Building 4 11-08-2004 05:36 PM
polyester matrix over urethane foam tjantti Materials 0 09-21-2004 05:21 AM
additional information Dim Open Discussion: All Things Boats & Boating 0 05-27-2003 10:26 PM
