| anyone to help on freeship hull fairing procedure?? having difficulties in spotting the right procedure on hull fairing....tutorials do not seem helpful at all tks |
| turn on curvature graph for some curve in the area of concern, then nudge the control points until the curvature graph looks nice and continuous.
| Yades, Marshmat has given you one way; another is to use the Gaussian curvature view.
__________________ Happy Sailing -Dan S. |
or may be I have not quite understood what you really meantks |
It seems to me a bit difficult to assess the fairness of a line (hence of a surface) based on a simple visual assessment of a gaussian representation tks yr help |
If you think a bit when making controlcurves, it is very quick and easy to get a perfectly fair hull with the curvature graphs. Gaussian view is really handy in areas where there are hollows, or transitions between flat and curved areas.
Now it's clear enough tks yrs yades |
| Using a small number of control points will produce a quite smooth surface. If you are trying to precisely duplicate an already existing design you may need to use a lot of points and use the techniques already mentioned. |
| A practical procedure for flotation and stability tests | Smarten | Boat Design | 4 | 06-02-2006 01:06 PM |
| Thru-hull Transducer mounting/fairing technique..? | paularey | Electrical Systems | 1 | 01-24-2006 06:32 PM |
| Fairing a cone to hull in maxsurf | Grant Nelson | Software | 3 | 01-07-2006 10:12 AM |
| Hull fairing software: Rhino vs. Prosurf/FastYacht | chomchan | Software | 2 | 10-18-2005 01:38 PM |
| Hull fairing software (big ship) | MaciekP | Software | 12 | 03-31-2004 02:24 AM |
