| In addition to that, can anyone help me on how to make the sheer line at the same elevation with the centerline..thanx |
| Select the center line, from surface menu choose extrude straight, and pull the surface past your sheer. From the curve menu choose curve from objects/ project, now project the sheer curve onto the surface. It will be on the same plane as the center line. This is only one of a few ways of doing this. gary ![]()
__________________ "The hand feeds the mind." Weston Farmer |
| Hi annasejahat, Another way would be: assuming the c plane we see in your pic is the world "top" c plane, and the vessel centre line is on y=0 (i.e. if you extended the centre line it would pass through 0,0 of the c plane)... - set c plane to "front" - project the sheer line onto c plane using the "project to c plane" tool, on the transform toolbar - voila! there it is. make sure you deselect "delete input objects" or you will loose the original curve. Rob |
| Tutorial CD for sale? Does anyone have the "Modeling for the Marine Industry" tutorial CD for sale? I prefer to avoid spending 80 dollars on it and then it possibly sit on my shelf because it was too confusing or for any other reason. Thanks. |
