| any software for finding the lightship weight and position of centre of gravity to find the weight of the lightship manually is so hard and time consuming, Is there any software for that kind of calculation? I want know , what will be best process for calculating the weight of the ship and position of centre of gravity? It will be nice if there ase some good softwares for that. thank you. |
| Hi Pavel, Calculating lightship always takes time and patience. The guys at Proteus made a plug-in for Rhino that helps tag items in your model with weight information for exporting to Excel. http://www.rhinomarine3d.com/ModelManagement.htm Thanks, -Steve |
| PAvel are you an student? or just crazy for boats? Yes, is called spreadsheet.....Excel or any spreadsheet, there is no software that can do such for you all of them requires your input some software can help you organize the weights but no to the point that you are "flying" (going fast) trough the process you still need to work on it, also you need to have and idea of what are you building you need to know your structure and general arrangement so you know what is installed onboard so you are able to locate them and obtain the preliminary CG. I thik everyone use a spreadsheet but again you need to have an idea beforehand of what you are building and how. This is what you are looking for: http://users.isp.com//vsw/pwe-pg1.htm |
| thanks! @CGN , yes I am a student of Naval architecture (complited 2nd year) |
| TouchCAD comes with an integrated weight / center of gravity calculator, where you specify the point weight or weight per area unit of each object or panel used in the model. This can at any time be evaluated in terms of weight and center of gravity, either for any number of selected objetcs, or complied in an integrated spreadsheet. This spreadsheet can be printed, or exaported to for example Excel. www.touchcad.com
__________________ Claes Lundstrom |
| free software for finding stabiliy??? | pavel915 | Software | 12 | 12-05-2006 04:02 AM |
| Rotate pulleys using gravity. | Jigar111 | Propulsion | 18 | 12-02-2006 12:12 AM |
| Centre of effort and keel position. | AleX`G | Sailboats | 6 | 08-06-2006 10:20 AM |
| Problem: Lightship displacement using movement of weights | chango | Software | 3 | 02-22-2006 01:36 PM |
| Longitudinal Centre of Gravity (LCG) | jileateta | Boat Design | 2 | 02-02-2005 11:06 AM |
