| ansys unit system Hi you can find ansys unit system table at the attachment.I want to ask a question about this table. You will see SI unit systems on the table as milimeter and meter. If we use SI unit system as milimeter what will be gravity force's value 9,81 m/s2 or 9.81e-3 m/s2(because of tonne) . Or will we chose the gravity force as 9.81m/s2 for all unit systems. How does ansys consider gravity force.What are your comments about it. Thanks Best regards |
| All FEA is unitless and deals with Force, Stiffness and Deflections. Results are calculated based on these. So to work out your units for gravity, it depends on your density units as well. F=ma, m= volume x density. Just make sure your units are consistant throughout. You should buy Building "Better Products with Finite Element Analysis" by Vince Adams (link to Amazon page is www.tinyurl.com/fea-book ) Its out of print but every now and then it comes up second hand on Amazon |
| ilgazcan If you're unsure, make a very very simple model. Apply a force and see what the results are when compared with hand calculations. Then repeat with 'g' to see what the result is. Then you'll know... Failing all that, read the manual! |
| AutoCAD to ANSYS | issac82 | Software | 18 | 09-22-2009 09:11 AM |
| Maxsurf to ANSYS | xtrememachineuk | Software | 11 | 03-04-2009 04:51 PM |
| Problem!!! | surfingyetty | Multihulls | 3 | 12-22-2008 05:18 PM |
| Modelling composite beams in Ansys | fencer | Software | 3 | 03-05-2006 08:39 AM |
| Modelling composite beams in Ansys | fencer | Boat Design | 0 | 02-27-2006 01:41 AM |
