| Strange error in AQWAWAVE Hello!! I am trying to run the model of a catamaran into aqwawb to get the pressures in the nodes of the hull to make an strength analysis in ANSYS. But when I run the aqwawb after a few seconds appears this message in the out file: **** SYSTEM ERROR **** MDCOPY:FAILED TO COPY FILE TO AQWAW001.RES I've made the same simulation with other model and I have the same problem. Does anybody know how to solve it? Thanks a lot. Alex |
| What is the meaning of the numbers in 1TUBE 36(1)(90000)(90001)(90000)(90000) ?? according to the html aqwa help... Deck 2 - Element Topology 1st Node, 2nd Node, Material Group, Geometry Group seems the 1st node is 90000 ..... but 36?? (1) ??? .... thank you. Do you need to define the cylinder in the designmodeler.... thank you... |
| Mesh creation in ANSYS AQWA for Sea Keeping Analysis | neodesigner | Software | 32 | 11-13-2012 07:39 PM |
| relative motion of two structures in Ansys AQWA | Don_Jan | Software | 6 | 12-10-2011 06:24 PM |
| ANSYS AQWA hydrostatics problem | MartijnO | Software | 0 | 02-22-2010 07:25 AM |
| Strange Westerbeake overheating problem | Capt. Mike | Diesel Engines | 56 | 10-10-2009 07:32 AM |
| Ansys problem | amateur mariner | Software | 17 | 06-01-2009 09:38 AM |
