Old 03-27-2006, 07:51 AM
jprev jprev is offline
Rep: 10 Posts: 37
Another FreeShip Question
How would I add a separate surface plane to FreeShip? I would like to add floors at different levels inside the hull. I know how to extrude a boundary edge but I can't seem to find anything that will let me add a horizontal plane, say 6" above the waterline. Is this possible?
Thanks,
Joe
Old 03-27-2006, 10:25 AM
lewisboats's Avatar
Obsessed Member
Rep: 1098 Posts: 1,731
Thanks,
Joe
Best way that I can figure is to extrude the sheer like you are going to make a deck...but only an inch or so. Then extrude again and delete the inch. Creat points at the level where you want your floor and note the y and z coords. Move your floor down to the correct level and shape it to match your hull using the z coords then zero out the y on the centerline so it will match the centerline of the hull. Kind of a roundabout way of doing it but far as I know...the only one.
Steve
Old 03-27-2006, 11:35 AM
jam007 jam007 is offline
Rep: 12 Posts: 89
FreeShip only uses 2D-surfaces. One surface can not be split in two. Therefore you have to treat inner and outer surface of the hull as separate surfaces. Either use "lewisboats" method or create an inner hull+deck continuation of the hull surface.
"Think like a painter not a carpenter" might be a FreeShip saying
Anders M
Old 03-27-2006, 01:28 PM
Rep: 10 Posts: 37
Thanks! I'll give that a shot.
Joe
FreeShip lewisboats Software 6 08-03-2009 12:52 PM
FreeShip Questions jprev Software 2 03-22-2006 06:55 AM
Freeship question Windvang Software 5 01-10-2006 09:48 AM
FreeSHIP 2.1 lewisboats Software 5 11-06-2005 06:35 AM
