Old 11-08-2008, 10:06 AM
ConcreteCanoe10 ConcreteCanoe10 is offline
Rep: 10 Posts: 4
analyzing 3D hull
I am trying to analyze a concrete canoe hull design. We need to find the stresses to determine the strength for our concrete. I have drawn the canoe in freeship, and we also have an excel file of the points. Our plan was to put export the canoe into solidworks for analysis. However, solidworks can not analyse the canoe unless it is a solid object. At the moment it is a mesh with MANY points. Any ideas?
thanks, Jackie
Old 11-08-2008, 04:35 PM
daiquiri's Avatar
daiquiri daiquiri is offline
Engineering and Design
Rep: 2574 Posts: 2,731
You can export the hull from Freeship as dxf 3D polylines, import them in solidworks, and them construct the solid body from skratch using the imported polylines as guidelines.
Old 11-10-2008, 09:04 PM
Rep: 10 Posts: 4
Ok thanks I'll see what we can do.
Old 11-28-2008, 04:45 PM
thefuture thefuture is offline
Rep: 15 Posts: 28
I export hulls from freeship to dxf all the time. If you need help shoot me an email. Falls1gr@cmich.edu
Old 11-28-2008, 05:56 PM
CGN CGN is offline
Rep: 138 Posts: 547
why use dxf???, export as a iges from freeship, if you have that version, then import into solidworks and turn it into a solid, solidworks can thicken a surface and can "patch" a surface if you need to.
Hull finish on high speed hull. Polished or Matt? Sooty Boat Design 2 02-03-2008 12:08 PM
differences between nitro hull and vee pad hull riveramunizaga Boat Design 4 05-24-2005 10:27 PM
what is faster a flat boat hull or a vee pad hull riveramunizaga Boat Design 24 05-24-2005 02:18 PM
hull boat redesigns (hull pad project) riveramunizaga Boat Design 9 05-12-2005 08:35 PM
Hull or hull & deck broke apart during 40-50 mph turn Jeff Powerboats 1 07-09-2002 12:27 AM
