Advice on software to do a 2d drawing
Discussion in 'Software' started by captf44, Jun 10, 2015.
  1. captf44
    captf44 New Member
    Hello everyone
    New to this great site! I would like to be able to upload a photo of my boat and trace it to make a line drawing. what software should I use ? also are there any tutorials on how to do this? Any help would greatly be appreciated.
  2. DCockey
    Likes: 634, Points: 113, Legacy Rep: 1485
    DCockey Senior Member
    Do you want to trace over the photo to create a drawing of the photo, or do you want to create a set of "lines" of the shape of the hull starting with the photo?
  3. captf44
    captf44 New Member
    I would like to create a set of lines using the photo
  4. gonzo
    Likes: 1,718, Points: 123, Legacy Rep: 2031
    gonzo Senior Member
    A set of lines is a three view representation of a body. You would need to take many photos from different angles and stitch them. There is software that does that, but don't know how accurate it is. There are other methods that can give you a set of lines. From the high tech laser scanning to the traditional pulling of measurements.
  5. DCockey
    It is not possible to create a set of lines from a single photo. It is possible to create a 3D virtual model from a set of photos, and then to create a lines drawing from the 3D virtual model. Some learning and practice is needed.
    I use usually PhotoScan software to process photos and create a mesh model, and then Rhino 3D to refine the mesh model and create a set of lines. For boats with clean, glossy paint/gelcoat finishes I use PhotoModeler software with applied targets.
  6. Ad Hoc
    Likes: 1,688, Points: 113, Legacy Rep: 2488
    Ad Hoc Naval Architect
    Then you haven't seen Paramarine lines creation software.
    I was the agent for this software several years ago. One can scan in an image, a 2D picture from a magazine, select a few key-points and in seconds it creates a 'best guess' of the shape and produces a set of lines. It was very impressive.
  7. gonzo
    gonzo Senior Member
    Do you need to input dimensions?
  8. Ad Hoc
    Nope...just scan in the image as a bitmap...then select what you want using a mouse. That's it.
  9. gonzo
    gonzo Senior Member
    How does it figure out, for example, the beam from a sideways photo?
  10. Ad Hoc
    Beyond me..lots of very advanced and clever maths. You'd have to ask the software engineers how they did it.
    But it is extremely impressive to see...and scary too!!
  11. gonzo
    gonzo Senior Member
    We use software on a microscope that uses focus to calculate distance and creates a 3D of any surface to 0.01 micron. It could be used on a larger scale. I am really impressed that anyone can produce 3D out of a photo.
  12. daiquiri
    Likes: 258, Points: 93, Legacy Rep: 3380
    Button-pushers' wet dream. ;)
  13. captf44
    captf44 New Member
    OK. I think I am using the wrong terms. I just wan to trace a photo of my boat to create a simple 2d drawing. Similar to the drawings you find on the back of T shirts that boat owners have made
  14. daiquiri
    You need a software which can transform raster images (bmp, jpg) into vectorial ones.
    You might try this free online tool: http://www.autotracer.org/ just upload your pic, choose the output format (even dxf is available), eventually modify the output options and hit the "send File" button.
    The web page will return the vectorial version of your picture.
    Hope it helps.
    Cheers
  15. captf44
    captf44 New Member
    What about an autocad type software where i can trace what lines I want to go for a simpler design?
