Old 08-30-2010, 02:12 AM
Willallison's Avatar
Rep: 2319 Posts: 3,502
3D viewer for Rhino Models
I'm sure I've asked this before, but blowed if I can find it now...
Is there a free (or low cost) program available that will allow others to view (and preferably rotate or at least see animated images) of a 3D model exported from Rhino (or rather in a format that can be exported by Rhino)?
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 08-30-2010, 10:39 AM
apex1
Not sure if "CAD viewer" does that, but maybe worth trying, its freeware. It does work with solidworks files.
Regards
Richard
Old 08-30-2010, 10:53 AM
duluthboats's Avatar
Senior Dreamer
Rep: 771 Posts: 1,580
Rhino demo is free. I have made models for others and had them install the demo so they could look at it and take measurements. A great toool for free.
"The hand feeds the mind."
Weston Farmer
Old 08-30-2010, 11:22 AM
DavidJ DavidJ is offline
Rep: 433 Posts: 151
The demo idea seems like a good one. The problem is that you are then giving the viewer access to your native modeling file. If you are just trying to discuss ideas with potential clients I wouldn't want to send them editable files. If you are already entered into a contract and are trading information this would be the easiest.
Solidworks has their edrawings and Catia has a nifty 3dxml plugin, but I do not know of a Rhino export option for doing something similar. You could try downloading the viewers for things like that and seeing if they will open any of various Rhino exports - perhaps dwg?
Adobe Acrobat 3D is not free. However, it outputs pdf files that everyone can open with the free Adobe reader they most likely already have installed. It's a good option. Particularly if you are dealing with non-computer users on the other end. Or if you find yourself submitting lots of proposals.
I've never tried this option, but apparently google sketchup imports 3ds files. You could try exporting from Rhino as 3ds and then importing into sketchup. Or exporting as GHS to open with Deadweight.
Old 08-30-2010, 12:07 PM
apex1
When .pdf´s are a acceptable option, you can probably use "Free PDF" it emulates a printer and produces pdf files instead of printouts. I mail my CAD drawings that way when I don´t want to send the original drawing.
Regards
Richard
a example:
Old 08-30-2010, 02:34 PM
Joe Petrich Joe Petrich is offline
Designer
Rep: 141 Posts: 158
Try Simlab's 3D PDF from Rhino program http://www.simlab-soft.com/3d-plugin...hino-main.aspx. It's only $95 and there is a free demo. I have used it and it works quite nicely. It exports a 3D PDF file as the name implies. If the clients have the most current version of the free Adobe Reader (or I think at least version 7.0) they will be able to open it.
Try the attached PDF.
Hope this helps.
Horns.pdf
Old 08-30-2010, 05:57 PM
Thanks Gents... I'll give a few of those a try...
Will
www.imaginocean.net
Old 09-02-2010, 12:59 AM
FYI
I've downloaded the Simlab demo. My VERY brief play would suggest that it's very easy to use.
And the resulting pdf file is exactly the format I'd prefer to send files in.
Will
www.imaginocean.net
Old 05-05-2012, 11:13 PM
andrew jordon andrew jordon is offline
Rep: 10 Posts: 2
Check this site: http://www.publishyourdesign.com. You can upload and view exported Rhino models in browser without plugin. It supports Solidworks models as well. You don't need to share original design document. Tools are provided to export designs to a small visualization file format .pyd.
Old 05-06-2012, 09:08 AM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
This tool apparently doesn't work with Internet Explorer 9 due to use of webGL, and according to the publishyourdesign website requires a web browser such as Foxfire or Chrome. There are two plug-ins available which allow use of webGL with Internet Explorer but these are not mentioned on the publishyourown website. Incompatibility with Internet Explorer may be an issue for some users, particularly one as enterprises and institutions with centrally supported IT which have adopted IE as the standard browser.
David Cockey
Old 05-06-2012, 09:47 AM
Rep: 10 Posts: 2
David, you are right that IE cannot support webgl currently. The workaround I know is to install Google Chrome Frame plugin for IE (from http://www.google.com/chromeframe/eu...ickenable=true), which is mentioned in help page. What is the other IE plugin for WebGL support?
Old 05-06-2012, 10:34 AM
Engineer
Other WebGL plug-in for IE is IEWebGL http://www.iewebgl.com/
Following the link which appeared on my screen when I clicked on http://www.publishyourdesign.com I saw:
Oh no! We are sorry, but your browser does not seem to support WebGL.
You can upgrade by clicking this link.
You may want to download one of the following browsers to view WebGL content.
The following browsers support WebGL on Windows:
Google Chrome
Mozilla Firefox
You must enable JavaScript to use WebGL.
Nothing there about using the Google Chrome Frame plug-in with IE, only about using the Google Chrome browser. You might want to ammend this information to include the ability to use IE plug-ins.
David Cockey
2D Rhino to Autocad export and rhino sectioning fede Software 13 10-18-2009 02:55 AM
Scale models Matt.D Boat Design 23 09-29-2009 06:47 PM
Simple Wave Models In Rhino... Sean Herron Software 29 01-14-2009 07:30 PM
3d viewer and formats yipster General Computing 8 01-15-2007 04:24 PM
Viewer for ESSI-code Guest Software 3 01-31-2006 01:02 AM
