Old 08-18-2005, 03:17 PM
signum signum is offline
Rep: 26 Posts: 25
3D Rhino model and 2D drawings
I made a 3D model of boat in Rhino.
I wish to make 2D drawings from it. Which is the best way, using AutoCad or SolidWorks?
How should I save the file in Rhino to be able to export then in one of these two software?
Thank you.
Victor
Old 08-19-2005, 02:46 AM
Tim B Tim B is offline
Rep: 794 Posts: 1,407
I'd keep working in Rhino until you have done the 2D drawings, then copy it to autocad to put in the line-styles.
To export, select the objects to export, type "export" (no quotes) at the command line and choose the *.dxf file type.
Cheers,
Tim B.
Old 08-19-2005, 06:35 AM
JEM JEM is offline
Rep: 38 Posts: 299
You have a 3D model but need to make 2D panels? First you'll have to use the "unroll developable surface" function. It's on the "surface" drop down menu near the bottom.
Matt - JEM Watercraft
3D v 2D guest12020101217 Software 10 03-24-2004 06:33 AM
Yacht interior layout Polarity Software 48 04-13-2002 08:12 PM
3D hull model to 2D drawing cut patterns Software 10 01-30-2002 07:43 PM
