| 3d object convertor converts over 400 3d file formats but not all... easy small download at http://web.t-online.hu/karpo/ and i hear google is coming with a free 3d viewer? acrobat 3d is far from perfect and cost a grand |
| Check out SolidWorks e-drawings: http://solidworks.com. Click on eDrawings under featured links. The sofware is FREE. You can also see a demo of this on my site: http://sail2live.com/boats/sonadora/coolstuff.html |
| Hi Sonadora, This is nice software for viewing various files, but it doesn't seem to convert file formats at all. I sure wish it did! I would love to convert between Mechanical desktop and Rhino, for example. Bill |
| BillyDoc, You should be able to do this from MDT. I believe there is an IGES translator built in. Rick |
| Well yes, there is. But then you end up with a 3D mesh in Rhino that you really can't do anything with except admire. Or, anyway, I've never had much luck with it. The same is true going the other way. Bill |
| If you are interested in free translation with some work involved then read if you want magic solution go buy a translator Translation between rhino and cad this works fine and is free, some steps are involved but you can go form Autocad or MDT to rhino with a "clean" file using Acis and step. save from MDT as a Acis and use the free translation services on: http://www.steptools.com/strepo/logi...slate%2Ecgi%3F and convert form Acis to step and open the step file on rhino. Or save from rhino as Acis file and download this viewer/converter from: http://download.spatial.com/viewer/A...15_install.zip and save the acis file as a lower version of Acis... for example save it to version 3 and MDT will be able to open it, it may open it now with out translation but it has work for me before. In general Acad (MDT) and rhino don't play well specially complicated objects so success i will say is not limited is just that for some reason they just don't "play" as we would like. Looking at the new version of Autocad seems that more "surfacing" is "coded" into the latest version of Autocad. cheers |
| Thanks CGN, that's good info to have! A good part of my problem with MDT is that it is old (version 4) and I don't intend to "upgrade." Once burnt, twice shy as they say. Getting close to retirement anyway, so should be moot except for the boat. And for that I've been having pretty good luck with Rhino and Freeship. Actually, Freeship is amazing! Bill |
| Transform 2D plan into 3D object | Archive | Software | 19 | 08-18-2004 09:42 PM |
