| 3 panels plus transom = amphib airplane hull Greetings- I want to build a hull for a small airplane and I dont think it could be any simpler than to have two sides , a flat bottom and a transom. I will add a long box to the rear at the appropriate angle to allow the plane to rotate on the water when taking off and provide floatation rear of the center of gravity. As I have browsed through Carlson's sample hull designs, it looks like probably the Piroque has the necessary panel layout, I would just like to drag and drop a bit to alter dimensions and then be able to "unfold" the panels to the flat layout and output to a plot file I could take to the print shop and print my patterns. It is easy enough to drag and drop in Carlsons program to alter the shape but I dont see where you an unfold the design for producing flat panel patterns etc. I've spent hours looking at many comments regarding at least fifteen software programs here, but for something so simple as I want to do, Is there anything more sophisticated than Carlson that will allow me to drag and drop that will also be easier or more intuitive? I really dont want to try a dozen programs if someone can just point me in the optimum direction. I dont mind paying a little for the software. Suggestions are welcome. Thanks Scott |
TouchCAD allows you to calculate the weight and center of gravity with individual weight per area unit or point weights settings for each unit and compile it into a built in spreadsheet (or export it if you prefer that). TouchCAD can also unfold just about anything. The entire process is dynamically linked to the 3D model and any changes done in 3D are automatically updated in the Unfold view, very useful for optimization of the use of the material. The unfolding features are highly parametric in a very wide range of ways (direction of strips, strip resolution, overlaps, automatic panel and vertex numbers, automatic coordinate measurememnts with individual settings for each panel, alignment marks, individual seam/overlap settings for each panel side , folding lines, etc). The Unfold view also allows you to move, rotate and flip the panels to allow you to generate cut out layouts to fit within a given set of sheet dimensions. The enclosed picture is essentially a simple scribble (I think I spent something like half an hour to a hour on it) so you have to forget it if it does not look much like an aircraft. Mor info at: www.touchcad.com /Claes
__________________ Claes Lundstrom |
| amphib airplane hull Thanks for the info on Touch Cad. To be more spetcific what I need to do is build a piroque for the front half of the floating airplane hull with a box structure on the rear since no boat hull programs support steps I dont think as are used in all pontoons for aircraft etc. I have attached a side view of what I was able to generate in Carlson's hull design in about 30 minutes after first starting the program. #1 This shows the whole length of the hull and #2 shows my doctored image showing the step. #3 and #4 show the separate front half and back half separated for design purposes. I have no CAD background and I am afraid any CAD program may require hundreds of hours to get this very basic layout that I would like to build out of either plywood or foam board sandwich. Thanks Scott |
| Something like this jpeg? Five minutes in Maxsurf, three trimmed surfaces. I have uploaded this design to the Maxsurf Academic sample designs page if anyone wishes to download it.
__________________ Andrew Mason Formsys http://www.formsys.com Maxsurf Academic http://www.formsys.com/academic/maxsurf/ |
| amphib airplane hull Andrew- that is really a beautiful rendition of what would be a sleek hull for an amphib plane ... I was actually thinking flat bottom to simplify building but you may have changed my mind. I do know that like airboats a perfectly flat bottom requires the least possible power to plane on. I never plan to see any rough water in my airplane so a flat bottom will be ok. Thanks for the inspiration. Scott ------- Quote:
| Scott Obviously you need to be very careful with the design of floatplane floats, your life could depend on it. Whether you are using a stepped or unstepped bottom, I suggest you research the subject carefully as the location of any step and the angle of attack of the planing surfaces will be critical to perfomance and safety. I did a quick search and didn't find much for full size floatplanes, however the R/C modellers have a lot of info. A good starting guide is at - http://www.stenulson.net/rcflight/watrfly2.htm also some float manufacturers- http://www.ultralightfloats.com/water_article.htm http://www.zenithair.com/kit-data/floats.htm http://www.familyairtours.com/page14_aeroset.html regards Andrew
| seaplane hull. not plane with floats Those were some nice links and thank you for sharing. Actually my inspiration is from severa of two of the best photo galleries for small seaplanes on the internet. http://vulatalk.zdwebhosting.com/pic...oats/Page.html http://vulatalk.zdwebhosting.com/pic...ater/Page.html http://vulatalk.zdwebhosting.com/pic...ane/index.html http://vulatalk.zdwebhosting.com/pic...fish/Page.html I did study aerospace engineering and have had success in designing planes, but I am brand new with the boat hull activity. Sadly, Maxsurf is over my budget for this one time project. What a beautiful job it does however. Thanks again Scott |
| How about boat design definitions | JonathanCole | Boat Design | 55 | 01-24-2010 04:48 PM |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 06:48 PM |
| Jet Drive | Jet Drives | 15 | 12-18-2006 09:51 AM | |
| How to Create 3D Hull from Flat Panels? | DougChapman | Software | 4 | 09-20-2005 01:03 PM |
| Stepped Hulls | Ryon Macey | Powerboats | 53 | 08-01-2004 10:44 AM |
