| 26' Double Step,Pad bottom Hull Mold (FUSION) Very Fast hull,This mold was used to pull plug for one of the most popular 24' Bay boats on the market ???? $14,995.00 I will be pulling one part for myself be for molds leave my shop,so they will be waxed and ready to build from 941-685-9374 |
| can i build a infaltable rib boat with this mold? |
| not sure it would need a wide flange added to it I believe |
| is this for just the hull or do you have the deck as well ...can you send a picture of a popped boat from this hull to ivan2214@gmail.com and what speeds power info would be greatly apreciated thanks |
would you sell one? |
| Yes we will build you one $10,000.00 for Hull and Deck with stringers and bulkheads all composite call 941-685-9374 sorry no pics at this time |
| hi John, wish i could call you, but i am over sea currently. i need you to explain more of what will i get? and what about the materials used? do you have any PIC's of a finished boat from the same mold? did you try it? How does it ride? and what about the max HP can be used? one last thing is 24' or 26'? thanks |
| The mold is 26' over all For $10,000.00 you will get a Hull with Stingers and bulkheads,and it will be built with a combo of 1708 & 2408 coring the strakes and pad |
| molds Do you still have the 18 lightning "action" molds available? Thanks Marty |
| Pics of a part from this mold Transom was blocked off at 23' And yes I do have the Action molds again ,I have several I have to build and then the molds will be forsale ! |
| 26' Pad bottom with 2 step bottom hull mold only | johnboat75 | Marketplace | 1 | 03-07-2009 07:00 AM |
| Step bottom | vv3k4i | Boat Design | 1 | 09-21-2008 01:17 PM |
| differences between nitro hull and vee pad hull | riveramunizaga | Boat Design | 4 | 05-24-2005 10:27 PM |
| what is faster a flat boat hull or a vee pad hull | riveramunizaga | Boat Design | 24 | 05-24-2005 02:18 PM |
| Bottom modification, addition of "ride-pad", and or lifting strake extension or addit | Larry Farr | Boatbuilding | 1 | 08-01-2001 05:31 AM |
