| 20'tunnel For sale 20' tunnel boat molds. This hull has seen tripple digit speeds, and can hold 7 people. It's and open bow picklefork. Can be rigged for jet.I/O or O/B. |
| Can you post or send pictures of this boat? |
| Thanks for posting some pictures of the pontoon and 20'. I can't really tell anything about the pontoon. Do you have any other pictures? Do you have any pictures of the bottom of the 20'? Is it a true tunnel or modvp? you can email me more info and pictures to MirageBts@aol.com. Thanks, Brad |
![]() It would be considered a Mod VP, it does have a center pod. The pod is 1" below the out side sponsons, making it a leagal boat to run in the APBA. ![]() This is showing the plug being lifted out, you should be able to see the center pod and the top of the tunnels with the outside sponsons. It needed a little help with the water hose to float it a bit. |
| how much are you asking for the mold? armyrangerm203gunner@yahoo.com |
| $7,500.00 and you get the original plug to go with it. This means you own the rights to the tooling. The hull is all glass, so you could put a new deck on it and paint the hull and have a boat to show. Most of the deck is glass other than the front end, that was all done with wood, glass and bondo. You could just build a new glass front and glass it to the deck, quicker than building a new deck. |
| You can also make a deck boat out of the hull. Just put bulk heads from side to side and put a floor on it, with hatch's for storage in the center pod and the out side sponsons. |
| you still have this mold If so please call me at 19515676808 so we can work things out I'm very interested |
| will do. mid morning. |
| Scott, Giving up on the tunnel project ?? |
| No, there not going anywhere. This is to keep the devil happy. Devil being, resin hating wife. I can race this open bow in the Comp Jet class and in the Parker 300. Wouldn't that look odd, a seven passanger family cruiser running in a 300 mile enduro. |
| I keep hopeing to get a email with a pic of a deck plug that has simularites to a 25' Talon ! |
| Are the molds still for sale? email me at mkwdbdr@aol.com. I would like some more info. |
If you have never built a boat, this is not one to cut your teeth on. Start with something small. This boat is 3 times harder to lay up than a V hull, and uses 1 1/2 times the material, for a boat the same length. |
