| Yamaha P45 2 Hp Outboard Motor Hi. Please Could You Help Me. I Have Recently Aquired A Yamaha P45 2hp Outboard Motor For My Dingy.when I Run It In A Barrel It Runs Ok But When Its On The Dingy It Overheats. When Its On The Dingy The Tell Tale Holes Are Just Above The Surface And This Is Apprroximately 10 Inches From The Bottom Exhaust And 12 To 14 Inches From The Pprop. I Am Wondering If The Back Pressure Could Be Stopping The Flow Of Water Trough The Engine Block. Could You Please Advise Me On What Height Which Bit Should Be Above The Water As I Cannot Seem To Find Anything Out About It. Thank You Very Much. Steve. |
| Hello! You need to have the propel, and the thing with 2 holes on under water. We had the same problem, but we're saw an hole on the other side of the thing with 2 holes, and now it works! If you have questions, send me an mail on aage_92@hotmail.com PS! Sorry my english typing. i am an 13 years old boy from Norway |
| Auto engine marinization | DIY Marinizing | 231 | 07-01-2010 08:34 PM | |
| Outboard Motor Out-Mounts or Outboard Bracket Installation Recommendations | Guest | Powerboats | 9 | 08-28-2007 04:54 AM |
| Transom thickness for outboard motor 100 to 250 hp | hseneque | Boatbuilding | 2 | 08-19-2005 12:39 PM |
| Marriying Lawnmower motor to outboard lower end | Machnumber2 | Boat Design | 1 | 05-21-2004 12:04 PM |
| Mounting height of outboard motor | finfinder951 | Powerboats | 2 | 05-18-2004 03:31 PM |
