| Yacht Keels I have been building an Infanta design 'cousin' to Sopranino and Trekka [all designed by Jack Laurent Giles] but instead of the fixed fin keels of these 2 my design has a fixed hollow fin with a swing down centre-board. The dimensions of Infanta are - loa: 20'1" lwl:17'6" beam: 6'3" draft 2'6" & 5'6" with the plate down, ballast: 1000lbs in the fin. I have built the fin of sheet steel and have developed the fin in such a way that I can detatch it [with a bit of bother] to inspect it if necasary. However I am becoming concerned about the on-going maintenance of a centre board with marine growth etc getting into the C/B slot and wondered if there is any alternative out there in keel development that gives you shallow draft with windward efficiency - wings on the keel? etc ?? |
| You could try twin keels. |
| I don't know how they compare to modern winged designs, but Scheel keels can perform pretty well for shoal draft applications. |
| Looks like a well-integrated bulb keel with the bulb shape acting as an end cap. |
| Unfortunately the physics of keels says their drag due to lift is inversely proportional to draft-squared. So while you can perhaps make some minor improvements, shallow draft is going to impact windward ability.
| The great Herrishof figured that a 7-1 ratio between LWL and draft would work in all cruisers going to windward. So a 28 ft waterline would have about 4 ft of draft. No in calm water she wont point as high as a "race" boat sailing on the Keel , just dragging the hull along, but in the ocean where some HP is required to advance into seas , the combo of hull and 1/7 draft keel works just fine. And is BETTER in light airs with less wetted surface than the lead mine. Going around the buoys or the world , ??? FAST FRED |
| Twin keel research | MikeJohns | Boat Design | 125 | 06-16-2009 11:44 PM |
| High Professional building & managing group of super yacht | george_moy | Services & Employment | 1 | 04-23-2006 04:17 PM |
| Yacht Designer Seeking Contract Work | jamiehides | Services & Employment | 0 | 08-30-2005 07:41 AM |
| Yacht Designer seeking employment | jamiehides | Services & Employment | 0 | 12-09-2004 08:39 AM |
| Dennis Conner's newest America's Cup yacht sank Tuesday off Long Beach | Jeff | Sailboats | 15 | 10-14-2004 09:20 PM |
