Old 01-10-2010, 01:27 PM
dalebirrell dalebirrell is offline
Rep: 32 Posts: 24
XFoil
Is anyone familiar with the lastest Xfoil program?
I was having issues loading some NACA sections. I opened a 63412 fine, then next time i ran the program i get an error message when trying to open the same foil again...?
Old 01-10-2010, 05:10 PM
wet feet wet feet is offline
Rep: 99 Posts: 264
I have to admit finding Xfoil a bit challenging.So I shelled out ten euros for Profili which I have found rather more comprehensible.As I understand it the same processes run behind a fairly easily navigated interface.
Old 01-10-2010, 06:06 PM
tspeer tspeer is offline
Rep: 1395 Posts: 1,537
Did you upgrade XFOIL versions in between?
Check the file for tabs and replace them with spaces. You probably did this on the original file, but maybe you've saved the coordinates from a spreadsheet and didn't use the exact same file as before.
Tom Speer
Old 01-10-2010, 06:48 PM
Previous Member
Rep: 0 Posts: 0
I find JavaFoil easier to use than Xfoil although I have not spent much time with Xfoil:
http://www.mh-aerotools.de/airfoils/jf_applet.htm
Rick W
Old 01-11-2010, 09:15 AM
Rep: 32 Posts: 24
thanks guys, appreciated
Want Xfoil, do I need Unix to use? shu Software 3 05-27-2009 11:27 PM
Xfoil in batch mode fastwave Software 1 12-13-2007 02:09 AM
Any help appreciated: Airfoil design and using xfoil bwoo Boat Design 9 04-26-2006 04:05 PM
XFOIL for hydrofoils boogie Boat Design 10 02-07-2004 01:52 PM
XFoil - NCrit nico Software 0 10-10-2003 02:43 PM
