| Wyliecat Rig vs. Modern Sloop Rig Performance Saw the following posted sometime ago with no reply. How do you think these two boats would perform against each other? On the subject of Wylie, would someone like to crank up their VPP and run a fictitious race between a Wyliecat 44 and a Coutts 44? Who wins? Why? http://www.wyliecat.com/yachts/models/wyliecat_44.html http://www.rc44.com/ http://www.v1-tech.com/wp-content/files/File/RC44.pdf |
| "I also wanted a boat that could be sailed short-handed with a deck layout incorporating many non-standard adjustments." Quote from RC So should the comparative VPP be run with 1 or 2 crew? Triangle,Windward-Leeward o.k.? |
| You're not going to get any meaningful VPP results without extensive data from the hull and appendages, and an accurate load condition with weight and center of gravity. Chances are the Wylie cat rig falls outside the empirical data used to develop the VPP algorithm, so the results for that boat may not be reliable anyway. |
| Thanks for your interest and replies. I'm interested in a comparison on windward-leeward course scenario with a small crew of 4 on the Wyliecat and full crew on the RC 44. What do you think could allow us to do the best comparison of performance between these 2 boats? |
If you're lucky, these boats will enter an event where they sail the same course at the same time and you can look at the elapsed times. Or you may be able to get ORC VPP polar plots from the manufacturers and compare those. |
| Here is a great picture of a Wyliecat 44 racing several years ago; I think this boat has been converted to a sloop rig and is up for sale. http://www.flickr.com/photos/lawatt/...n/set-1256301/ http://www.yachtworld.com/boats/2006.../United-States |
| Bi-rig performance cruiser | Nordic Cat | Multihulls | 33 | 12-31-2009 09:54 AM |
| Converting a Bermudian Sloop to a Junk Rig? | mattnedgus | Boat Design | 3 | 10-06-2007 05:57 PM |
| Sloop verse Square Rig, Maltese Falcon vs Mirabella | brian eiland | Sailboats | 28 | 06-10-2007 10:13 PM |
| Modern Gunter rig | catsketcher | Sailboats | 4 | 12-24-2006 09:40 AM |
| sloop or cat rig? | Andy P | Sailboats | 3 | 09-12-2005 08:31 AM |
