Old 01-26-2010, 01:35 AM
N2dweb N2dweb is offline
Would this idea work -a 14Ft Curved Bottom Plywood Boat
14Ft Curved Bottom Plywood Boat - only 4 seams. Materials 4ea sheets of 1/2” plywood 4x8 4ea Studs 2”x4”x8’
Steps: 1. Scarf joint 3 of the plywood sheets to create a single sheet 8’x12’
2. Curve sides by placing sand bags in the middle (4 feet on each side), allow a week or so until the plywood is uniformly curved. Looking for 18“ to 24” sag over the 8 feet.
3. Cut and attach studs to top edge of plywood to brace and maintain the side curves to the boat.
4. Cut and attach plywood to the stern of the boat
5. Cut and attach plywood to the bow of the boat
6. Apply epoxy coat
7. Add additional support and trim
8. Add a raised plywood deck to the bow of the boat
9. Add seating and storage as desired.
Below is a quick sketch:
Plan on using the boat to fish in the back bays Galveston/Surside Tx.
Thanks in advance!
Old 01-26-2010, 05:55 AM
Rep: 1493 Posts: 7,447
The bow (green) section is a bulb. Plywood won't bend to that shape.
The hull has very little initial stability, it will be very tippy.
It will have a very high resistance, that is it will be hard to move in the water.
Overall it is a bad design with nothing to recommend it over a normal design.
Old 01-26-2010, 08:45 AM
mcollins07 mcollins07 is offline
Rep: 156 Posts: 206
It looks like you want ease of construction. The stability of such a round bottom would probably be a problem. Add one chine on each side and the construction will probably be easier and you will gain stability.
How do you plan on powering the boat?
check out PDRacer.com If you are using an outboard, then make the stern a less curved.
Old 01-26-2010, 10:45 AM
Rep: 749 Posts: 1,314
You have presented your case with clarity. Sorry to tell you that this is an idea that is not worth further discussion. This will not be as easy a build as it might seem. Better to build in the tried and true manner and end up with a seviceable boat that has some lasting value.
Old 01-26-2010, 05:33 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
You won't curve 1/2" plywood to that radius without some serious wetting and jacking. Too stiff.
N2dweb, you are approaching the art of boatbuilding from the wrong perspective. Though you are clever and have the rudiments of putting structures together, you might spend some time learning how others have done it. There are just too many issues you don't know enough about to consider.
Anything can float and "go" to some degree, but here you can learn to do a lot better than just floating and going. To design and build a real usable boat that's light enough, fast enough, and practical to build and own, takes years of experience in the field. Yet you can buy plans from such a designer for peanuts.
There's enough challenge to just building from plans.
Old 01-26-2010, 11:35 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
You will get a much sharper bend in the middle of the scarfed ply sheet than along the edges, not what you want. But keep trying and asking questions! We all had to start someplace. One of my early ideas was a lot like this one. If you are dead set on building boats to your own designs rather than a professional's, start with models and progress to a few small boats first like a canoe or rowboat then move up. it's a faster and cheaper way to learn. But if you just want one boat then buy a plan!!!
Dances with Turkeys
Old 01-27-2010, 11:32 AM
Well said Alan.
Old 01-27-2010, 11:52 AM
JLIMA's Avatar
JLIMA JLIMA is offline
crazed throttleman
Rep: 130 Posts: 101
Just curious why the round bottom? In your medium ie plywood a "vee" bottom is much simpler to construct and easier still is the flat bottom. Going along those lines a flat bottom and a simple "transom bow" that angles forward is a relatively simple build with out curves is much more stable and such boats have been used for years and get up on plane easily with a 10-15hp outboard. They are high suited to calm waters, and while I highly recommend a proper designer which I myself am not, such a boat is very simple to figure out. I apologize for bursting your bubble so to speak but plywood just can't be bend in the shape of the bow your intending in your sketch.
Answering AAII based on reserve steam
Old 01-27-2010, 05:09 PM
aka Terry Haines
Actually the shape of the bow in N2's sketch can be achieved in ply. It's a cylinder with it's axis at 45 degrees so it appears to be a semi-ellipse in both the end and side elevations. However it creates a lateral chine across the bottom of the boat which will make for a lot of drag and turbulence.
Dances with Turkeys
Q: How to create a single curved surface in Rhino for Plywood planked Yacht Tender JAK Software 6 06-02-2009 02:17 PM
pontoon Idea! will it work??? yarrick88 Boat Design 10 06-15-2007 11:36 PM
using 2 sheets of plywood for bottom and sides of boat Bryan Campbell Boat Design 8 03-08-2006 11:58 PM
Plywood Narrowboat Idea Trywithply Boat Design 3 11-27-2005 02:22 PM
14ft Clinker Plywood Runabout Matt74 Wooden Boat Building and Restoration 1 11-07-2004 08:59 PM
