Old 03-07-2003, 12:33 PM
edneu edneu is offline
Rep: 10 Posts: 44
Wooden Splines
Does anyone know a source for wooden splines? I have a set of standard plastic splines and would like to experiment with splines of varying stiffness/flexibility. I have not found a source for them, there is barely a source for plastic (acyrlic) splines. Anyway if you have a few extra wooden splines laying around, we should talk.
Ed Neu
Florida
Old 03-07-2003, 09:05 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 645 Posts: 1,723
I have a pretty full set of 1940's Stanley basswood splines, including the rare and very breakable (don't ask, I used to have 2) "ship midsection" spline that tapers to nothing and comes back.
Bad news is I want to keep 'em. Other bad news is that you need British-style spline weights for them, without the chisel-point.
However, you are indeed a person of great taste and perspicacity if you are even _looking_ for a set. ;-)
If I find another I'll let you know.
Old 03-10-2003, 11:21 PM
Rep: 1493 Posts: 7,447
I make my own. All you need is a table saw with a fine tooth blade, a hand plane and sandpaper.
Old 03-13-2003, 08:56 PM
SailDesign's Avatar
Gonzo - that's a sure recipe for toothpicks in this household. ;-))
Old 03-13-2003, 11:16 PM
I know it takes some work. However, maybe I'm hard on my splines. I just finished lofting a launch of my design an found a good alternative. After cracking two of my wooden battens, I went into my sail bag and took a fiberglass batten. It worked really well without breaking. I am going to buy some full length sections.
Old 03-17-2003, 12:51 PM
8knots 8knots is offline
A little on the slow side
Rep: 349 Posts: 266
try some acrylic....
I have made a few from acrylic sheet that I liberated from the trash at work. Most sign shops have gobs of plastic laying around.
The best is Acrylite SG (sign grade) sg is a hybrid acrylic more flexible than old FF acrylic but not quite as hard to work with as Lexan is. I fabricate all of my foundry patterns from it too. Standard thicknesses are .118 and .177. Ask your local sign shop for some drop to play with. Runs for about $2.50-3.00 a sqft. If you make a set and like em. put them up for sale! I will have the bronze ducks to match in about 2 weeks.
Good luck 8Kts
Old 03-17-2003, 02:22 PM
What is the longest you can make?
Old 03-17-2003, 10:52 PM
Rep: 349 Posts: 266
size..
The standard sheet size is 75" x 100" but you can get it in 4' x 8'
use a good carbide blade and feather boards on that table saw. You do not want to overfeed the material as it will overheat and leave a gummy edge. you can sand to 400 wet then flame polish the edges with Ye-Olde propane torch. practice first on some scrap you can scortch the edge in a hurry. "a little bit at a time"
good luck 8kts
I removed the wooden plateau and replaced it with a fabric trampoline - stability?? Gregor_L Sailboats 2 04-10-2005 08:28 PM
wooden boats in Tasmania Unregistered Wooden Boat Building and Restoration 9 02-26-2005 11:08 PM
Wooden or Fiberglass berkin Boatbuilding 10 12-31-2004 02:42 AM
Painting a Wooden Hull Guest Boatbuilding 1 09-23-2003 09:11 AM
